I have a 93 that I will be flushing and changing the brake fluid on. Does anyone have hints or a procedure to make the job go smoother. This is my first vette and I haven't done this before on one. Any help would be appreciated.
It's pretty easy. I use a six point 10MM to break the bleeder loose, then put an open end on it for the bleeding process. I do this so often my wife doesn't want to help anymore so I'll be getting a Motive bleeder. I keep an old anti-freeze jug with a clear rubber line in the shop, just hook up the line and bleed away. One person must depress the pedal and the other person runs the bleeder.
I picked up a set of speed bleeders at AutoZone. I also use the Valvoline Synthetic Brake fluid in both my truck and wifes car and absolutely love it. Haven't had a chance to do the vette yet, but I need to. Works like a champ and is compatible with DOT 3&4 just in case you don't get it all out.
Thanks, I will pick up a set on the way home. Do you get the fluid out of the reservoir or just let it bleed out at the wheels? How long of a job is this, about an hour? Is there a specific sequence that anyone out there follows? Thanks for all the great input, especially the speed bleeders.
The reservoir must be kept full. Just to bleed the brakes and change the bleeders, an hour is tops. Depending on how you want to do it, you may want to pop the rear wheels off, that will add some time. It's very fast. If I remember right the sequence is RR LR RF LF. As you are not going to get the ABS bled, you may want to activate the ABS some and bleed again soon. There would be real hurry though unless the fluid is super bad.
Jim:
That depends on how your doing in:
1. buy brake one-man kit and 4 speed bleeders: about 30-60min, depending
2. Doing by hand x2 person: sometimes a little longer.
3. Get a pressure bleeder: 30 min.
That does not include tire removal time.
Sequence: RF/RR, LR/LF (i think, don't have my notes with me..)
So if I am trying to flush the system of old fluid, do I just keep bleeding the brakes until I feel that I have all new fluid in there or is it better to drain the system and then try and fill. I thought that if I drained the reservoir and refilled with new fluid and then bled all four wheels around 2 or three times, then I would have basically flushed my system. Any thoughts?
I just did my wifes car. To make life easy, remove all four wheels. Starting from the right rear, left rear, front right, front left. Just think of it as you are starting from the furthest wheel down to the wheel that is the closest. If you use the synthethc fulid you can tell once each line is bled by the color of the fluid. Synthethc fluid is clear, the old fluid is dark. It only took me an hour to do her car and that included removal and reinstalling of the wheels. Good Luck.
From what I've been told (haven't tried yet) you don't want to let the reservoir run dry. Then you have to start dealing with air bubbles in the lines, ABS, etc, and that will suck.
Better off to just buy two jugs of brake fluid, and bleed each caliper one at a time until the fluid runs clear. Do not let the reservoir suck in air, keep topping it off as you go along.
And the order should be furthest away from the master cylinder to closest... on my 94 it's RR, LR, RF, LF.
Thanks, that's exactly what I was worried about, introducing air into the system. I think I have a plan, now I just need the energy. Thanks for everyones help.
You can get some ATE blue, you'll know when there is fresh fluid when you see the blue. What I do when I do a complete flush is pump about half the reservoir through each caliper. (mine is dual reservoir) I just estimated the line as probably not holding more then that.
I have a doubt.
There are some bleeding / flushing methods out there like:
1. Power bleeding
2. Using Vaccum
3. A frind pumping the brake pedal
4. Gravity
This last one intrigues me. If I loosen the bleeders would fluid leak or would air be suck into the lines?
I think that using Vaccum is a good method when there is no help around.
I have a doubt.
1. Power bleeding
2. Using Vaccum
4. Gravity
Hope some opinions are shared.
Unless you reversed gravity, the fluid would just sit there. Though I have never done a gravity bleed, perhaps the line needs to be disconnected so it can drip downward. Vaccum bleeders cost about as much as the Motive pressure type. I decided to just get speed bleeders for mine.
The speed bleeders work great. I just replaced the brake lines yesterday with stainless ones and I flushed the system in the process. The speed bleeders didn't allow any ai to suction back into the system so you can do the job alone.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You are on the right track.
Bleeding sequence makes absolutely no difference....just bleed each one until fresh clean fluid starts coming out.
(start with new fluid in the reservoir...)
Put a clear plastic tube on the speed bleeder and the other end in a cup of liquid. When it flows clear and with out any bubbles, go to the next bleeder until complete.
