Coolant filter?
Old May 8, 2007 | 02:37 PM
rickneworleansla's Avatar
rickneworleansla
Default Coolant filter?
I found these searching the internet. I flush and change my engine coolant yearly so I don't have any probelms with my coolant system. I could see where if it got clogged it could possibly impede the flow of coolant and cause overheating. If I had known about these I may have considered putting it in with the Dewitt install. I was just curious if anyone has used one and what their experience was with it?
http://www.jag-lovers.org/xj-s/book/CoolantFilters.html
http://www.midnightdsigns.com/Mustan...%20Filter.html
http://neptune.spacebears.com/cars/stories/sctefba.html
Old May 8, 2007 | 03:21 PM
nogoodsam's Avatar
nogoodsam
I like the idea....listening....
Old May 8, 2007 | 04:02 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I definately like this idea too. It would help with the corrosion floating around thats for sure. I have never heard of a product like this before.
I wonder if its actual beneficial, or if its just one of those products there to make money from something obvious that doesn't harm anything.
Old May 9, 2007 | 11:12 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Like the idea. I wonder if those GM or Barr's radiator pellets could clog one?
I know you're supposed to crush them before adding them to the system, but some people just plop them in and let them dissolve on their own.
Old May 9, 2007 | 11:24 AM
SJW's Avatar
SJW
I'd have to think that if there were any significant benefit to such an item, at least one automobile manufacturer would already be using it, and I know of none that are.
Considering that the only moving parts in the cooling system are the pump, thermostat and heater control valve, having some solids floating loose in the system -- although not desirable -- isn't really posing much of a problem.
I'd say that the possibility of a filter introducing a restriction to coolant flow probably opens the door to a situation where the device can do more harm than any small amount of benefit that could be realized.
Regular preventive maintenance of the cooling system is your best bet.
Be well,
SJW
Old May 9, 2007 | 12:16 PM
Aardwolf's Avatar
Aardwolf
Be well,
SJW
It looks like a nice idea for a filter but a bit of a waste of money. I wouldn't use it.
Old May 9, 2007 | 12:20 PM
Goldcylon's Avatar
Goldcylon
Be well,
SJW
Anything can happen But I disagree with the "since not one automobile company has used it yet analogy" that it is still not a great idea. If was a clear visual filter media that could be seen and easy to determine it was getting clogged with contaminants then this would be just another area to look at when pulling the dipstip. I beleive one of the article examples was a clear filter media. Neat little idea.
Old May 9, 2007 | 12:44 PM
GIJoe's Avatar
GIJoe
Doesn't ALL the fluid, rusty particles and all, run through those tiny little tubes in the radiator, and that little opening that the thermostadt leaves once its opened?
Does rust grow if it gets lodged into places where it can sit and build up for a while?
Old May 9, 2007 | 08:43 PM
Goldcylon's Avatar
Goldcylon
[QUOTE=GIJoe;1560179341]Doesn't ALL the fluid, rusty particles and all, run through those tiny little tubes in the radiator, and that little opening that the thermostadt leaves once its opened?
Does rust grow if it gets lodged into places where it can sit and build up for a while?[/QUOTE
Old May 9, 2007 | 08:52 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I've never heard of coolant getting so bad it clogged the radiator tubes. Corrosion yes, but debris, no.
If you filter it, the filter will clog and you WILL have a problem.
I say no, not because auto mfr's don't use one, but because it sounds like a bad idea.
Also rust doesn't grow. Once it oxides, it's done, the rust is rust. Only the base metal will "grow rust."
jimmers's Avatar
jimmers
Old May 9, 2007 | 09:07 PM
Demonic85's Avatar
Demonic85
...and eventually the rust will be broken down into finer particles. I've never heard of any kind of coolant clogging in a well maintained car. I would think that flushing the system on a regular basis like you're supposed to would get rid of all or most of the debris.
that the filter would probably get clogged and cause a problem.
To Coolant filter?
