How to Get diagnostic codes
Old May 8, 2007 | 09:47 PM
95!Vette!'s Avatar
95!Vette!
Default How to Get diagnostic codes
I am wondering how I would be able to get the codes from my cars computer without paying 85 bucks to run a diagnostic. Is there an easier way to find out how to get the codes out my car?
Old May 8, 2007 | 10:17 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
If you use the search function @ top, go 'advanced', include 'archives' in your searh, you will find what you're looking for...a bunch of times.
Old May 8, 2007 | 10:19 PM
ynk1121's Avatar
ynk1121
http://www.corvettebuyers.com/c4vettes/codes.htm
Old May 8, 2007 | 10:31 PM
95!Vette!'s Avatar
95!Vette!
what does that mean short pin 12 to pin 4? how do I do that ?
Old May 8, 2007 | 10:37 PM
ynk1121's Avatar
ynk1121
get a wire or paper clip and connect one side to each pin
Old May 9, 2007 | 01:24 AM
corvette49rdave's Avatar
corvette49rdave
You can get a cheap (less than 30 bucks) code reader for your Vette at any Pep Boys, Kragen (Shucks) Auto Parts, etc. The unit plugs into your computer via a harness plug under the driver side of the dash (near where your right knee would be when sitting normally in the car). Follow the directions included with the code reader, and you should be able to access any trouble codes being sent by the ECM.
Old May 9, 2007 | 02:22 AM
cherry91's Avatar
cherry91
Default Code reader
I'm not sure about where you live but here in michigan autozone and Murray's discount auto read codes for free. Only takes about 5 minutes. hope you have one of them close to you.
Old May 9, 2007 | 08:10 AM
jimmers's Avatar
jimmers
Old May 9, 2007 | 12:23 PM
95!Vette!'s Avatar
95!Vette!
ok guys I got the codes, I went to autozone they told me that they can only do a diagnostic on 96 or better cars. Ok heres the codes I found C12,H22,H67 now I got to find out a code reader
Old May 9, 2007 | 12:36 PM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Tony,
MAD sells a nice diagnostic kit by Gordon Killebrew with various grounding plugs to check PCM, PKE, CCM, Etc. and an instruction book to help explain, troubleshoot, and clear basic fault codes. 94-96 Pn # 604-260 for 39.95.
Rick
Old May 9, 2007 | 12:53 PM
HG's Avatar
HG
c12 means On-Board diagnostics operational No DTC's. H22 and H 67 are history codes. that means they are not present now but were some time ago. not sure what year you have this is froma book on my 92 withan LT1. Disconnect the battery for a while and that should clear the two H codes. Here is some help. http://www.c4guru.com/modules.php?name=electrical or here
Old May 9, 2007 | 01:05 PM
95!Vette!'s Avatar
95!Vette!
Thank you very much I have a 95 Lt1 corvette auto. If im not correct please correct me the codes I found H22-TPS (signal voltage low) Throttle position sensor. And H67-Air conditioning Pressure Sensor circuit.Replace the air conditioning refrigerant pressure sensor. Please let me know if this is correct Thanks Tony
Old May 9, 2007 | 01:17 PM
HG's Avatar
HG
From my book on the 93, yes, they are DTC codes from the ECM, not the CCM. All ECM codes ( DTC's ) will be displayed by the CCM as history whether they are current or history.
Old May 9, 2007 | 01:20 PM
PDQUIK95's Avatar
PDQUIK95
Tony,
We would need to know which module you were in when you saw the code. It is either module 1, module 4, or module 9 as displayed on the odometer for each system tested. One module is CCM codes, one module is PCM codes and so on. These flash in order as you are looking at the odometer dash display. The same code number can show up for two different modules and obviously mean something different for each. I have the code book at home to tell you if you can check that.
Rick
Old May 9, 2007 | 01:44 PM
95!Vette!'s Avatar
95!Vette!
ok C12/1, H22/4, H67/9 Then A with no codes on top then 1.0 with no codes on top. Is that what you want? codes on top, and Module number on bottom, H22 is Pcm, and H67 is Abs/Asr module hows that.
Old May 9, 2007 | 03:17 PM
95!Vette!'s Avatar
95!Vette!
Would it be a good idea to go ahead and replace the TPS? would that cause my car to hesitate and cause tranny problems?
To How to Get diagnostic codes
