Need to know
Old May 8, 2007 | 10:26 PM
MICK C's Avatar
MICK C
5th Gear
Default Need to know
Two questions. First I need an extra ignition key. One on E- bay for $15 I need to tell him the vats #. Where do I find it? Also my 93 Dash goes off and on .Need to fix . There are a couple on e-bay but one is for a 92 and one for 96 .Will either work? Or do I need a 93 only/ Thanks,Mick
Old May 8, 2007 | 10:35 PM
ynk1121's Avatar
ynk1121
get an ohm meter and test the resistance across the chip on your key.
CODE---------RESISTANCE IN OHMS
1------------402
2------------523
3------------681
4------------887
5------------1130
6------------1470
7------------1870
8------------2370
9------------3010
10-----------3740
11-----------4750
12-----------6040
13-----------7500
14-----------9530
15-----------11800
Old May 8, 2007 | 10:39 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
You would need to take your key to a Chevy dealer, so that they can measure the resistance. This will tell you what key you need.
Not sure as far as the dash, but you may be better off getting yours fixed instead of just replacing it. I think there is a company that fixes them, but I am not sure of the name.
Good luck
Old May 8, 2007 | 10:56 PM
MICK C's Avatar
MICK C
5th Gear
Ok thanks. I'll look tomorrow about the dash.
To Need to know
