90 headlamp problem
Old May 13, 2007 | 07:42 PM
rgc729's Avatar
rgc729
Navigator
Default 90 headlamp problem
Intermittantly my left headlamp will go dim after you flip the dimmer switch. The hi beam indicator light stays the same when you flip dimmer but the right headlamp dims or brightens as it should. My driving lamps will not burn when low beam is selected but does when hi beams are on. Some times turning the headlamps off and then back on will rectify the problem. I have allready ckecked for bad ground. Is it the dimmer switch?
