Interior Lights Flash On
Old May 15, 2007 | 03:16 PM
Jag77's Avatar
Jag77
Default Interior Lights Flash On
I have been meaning to ask this question. When I am driving in the dark with my head lights on and I hit a bump in the road, my interior lights flash on and off. Is this normal?
Thx
Old May 15, 2007 | 03:25 PM
vlynnc's Avatar
vlynnc
St. Jude Donor '07-'08
We had the same problem right after we replaced the weatherstripping and had the car painted. The little contact button in the door jamb was missing. Once we replaced it, no more flashing lights!
Old May 15, 2007 | 03:40 PM
Goldcylon's Avatar
Goldcylon
Thx
Missaliagned or broken door contact
Old May 15, 2007 | 03:51 PM
REDEVIL's Avatar
REDEVIL
Check the door ajar switches for both doors. Mine was doing the very same thing, and found that both switches were bad. I replaced them (~$30 from Ecklers) and everything is back to normal.
Old May 15, 2007 | 05:48 PM
flyinlow90's Avatar
flyinlow90
Sometimes what you can do to buy you some time until you get the switches is tape a penny to the area where the door ajar switch makes contact with the body and the lights will not flicker.
What happens is the plunger does not go in all the way and the car "thinks" the door is open. Taping the penny there pushes the plunger in just a little farther for the switch to make contact.
Gary
Old May 15, 2007 | 06:34 PM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
Same thing fixed my 92's same problem! Good luck!
To Interior Lights Flash On
