My daughter took the vette on an errand. She had to use the parking brake, then forgot(?) it was on and drove home(about 3 miles). Rear wheel area smelled. Question: besides my daughter, will the car be okay? Thanks.
First just do a visual inspection for pad wear and hot spots or cracks in the rotors. How does it stop and does the ebrake still hold? Your car will be OK, but the rear brake pads and rotors are questionable, hopefully all OK.
I followed my Dad's cloud of smoke once (he was in a Rental) for 5 miles so I know the smell. Hard to say if there's anything other than some pad material missing. You could pull the wheels and check for scoring or bluing on the rotors. Otherwise if it's not vibrating when you apply the brakes - or making noise - or if it still stops the same - you probably will be replacing the pads and turning the rotors sooner than you planned on, but it doesn't have to be tomorrow. I certainly didn't on my Dad's rental - nor did we give it much thought when I was a pit crew member on a Bomber class stock car which lit up the rotors like a welding torch every time the driver applied the brakes - but then that class was suppose to be a little funky.
Hopefully I assumed you checked for functionaility afterwards. The braking brake light was not working? or was she drifting home?
Other than extreme premature wear to the back brakes unless you have some cable issue and you she didnt hear a crack and pop sound you may have got away with this one. Good luck.
Depends on the condition of your rear brakes - i.e. how "new" your rear pads are. If they are fairly new, then you're probably okay. If they were fairly well worn before she set the e-brake, then you might "need" to replace the pads and, possibly, the rotors.
Regardless, you might want to pull the rear wheels and inspect the pads and rotors just to be sure that you know the status.
