She left me stranded last night
Old May 19, 2007 | 03:22 PM
jserio's Avatar
jserio
O.C.
Default She left me stranded last night
When I was leaving work yesterday it seemed my gauges were not working. So I proceeded to make my way home. Then I noticed the temp gauge moving ( just a little. Since tuning the computer my temp stays at a little above 185). My volts guage was in it's usual spot. The oil temp and pressure gauges were still flatlined. So I started to hear tapping. I was on the side of the road in 2 seconds after I heard that.
Now I seems very apparent that my oil pump is gone. There are no fluid leaking from my engine. There was no smoke/steam coming from the engine nor was the engine unusually hot. I did a search but I could not find an R&R for the oil pump.
95 LT1 If anyone has a proceedure I would appreciate it.
Old May 19, 2007 | 05:49 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Originally Posted by jserio
...95 LT1 If anyone has a proceedure I would appreciate it.
Well, that blows. If no one shows up with a how-to, I can scan the R&R out of my 96 FSM. I'd be surprised if it wasn't the same for your 95...
Old May 19, 2007 | 07:38 PM
r.serio's Avatar
r.serio
Cruising
Joe. . . I forgot to tell you on the phone. If you need a long block, I have everything else you need. Intake, valve covers, accessory bracket, throttle body (it's nasty tho), I chucked the oil pan (damn), electric water pump (you can't have it , I just wanted to let you know I have one), water pump and anything else you may need. This way you can put this stuff on the new engine to save some time.
To She left me stranded last night
