PKE Programming
Old May 20, 2007 | 10:20 PM
hman1987's Avatar
hman1987
Default PKE Programming
For some reason my PKE fob is not working in passive mode. The battery is good.....it just does not automatically lock the doors and set the alarm. How do I reset it? I found the answer once before on the net but I can't find it again.
Old May 20, 2007 | 10:47 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Are you sure it hasn't been turned off?
Easy way to find out, just stand by drivers door and hold the door lock button down until you hear the locks cycle (about 2 - 3 seconds). If the system was off, it should now be on.
Easy to try anyway
Old May 21, 2007 | 12:48 PM
hman1987's Avatar
hman1987
I didn't turn it off. I just stopped working while in the garage.
Old May 21, 2007 | 02:07 PM
hman1987's Avatar
hman1987
Default Problem Solved
I did what you suggested and that was the trick. Thanks.
To PKE Programming
