ASR Question
Old Oct 22, 2001 | 06:55 PM
Guest
Guest
Posts: n/a
Default ASR Question
Hi, all. First off, I want to thank you for past help you've given me here. It's appreciated. :)
I've read threads on the ASR and am still a bit confused. Should I drive with this engaged 100% of the time, as a general rule? It's a '96 LT1, stock...used as a daily driver during the spring, summer and fall. I've always left it engaged and now I'm wondering if it should be.
Your thoughts?
Old Oct 22, 2001 | 07:05 PM
McShagger's Avatar
McShagger
Default Re: ASR Question (Mairi)
Yes, in general, you should have it engaged. I know sometimes it may seem like a bother, but it will save you some tire wear in the long run. Now if you really wont to screach the tyres, turn it off. :D
:cheers:
Old Oct 22, 2001 | 07:13 PM
Guest
Guest
Posts: n/a
Default Re: ASR Question (McShagger)
Hmmmmmmmmm....so you're saying the reason I haven't been able to screech the tires is because the ASR's on?? I've been soooo tempted to turn it off and try it....I've never had the ASR off, though - figured I'd screw something up.
Hehehehe...funny story - the guy who sold me the car tried and tried and tried to impress me by laying rubber in front of my house. No rubber; no screech. Next time he came over, he sheepishly admitted he had the ASR engaged and found out he couldn't lay rubber with it on. Consider, though, this is the same dude who told me only the '95's and '96's had the square taillights. You guys here educated me on that point. ;)
Old Oct 22, 2001 | 07:29 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
I leave mine off... it's almost gotten me killed before and I prefer to have control over my gas. If it's raining, I'll leave it on.. otherwise, no way. The delay that it takes to recover is too long in my book.
Old Oct 22, 2001 | 07:34 PM
Guest
Guest
Posts: n/a
Default Re: ASR Question (Springer's 95)
Springer, could you explain what you mean by it almost getting you killed before? Will I notice a difference in daily driving with it off?
Old Oct 22, 2001 | 08:35 PM
Springer's LT4
Mairi..
I was crossing with an intersection with a bump in the road.. rear of the car bounched up a bit and the ASR kicked in... when it did, I couldn't give it gas right away and had traffic starting to come at me...
To me, the way it works just doesn't seem like it's simplemented correctly.
Old Oct 22, 2001 | 08:42 PM
Guest
Guest
Posts: n/a
Springer, this is going to sound entirely dumb....but is this what causes the back end to jump around?
Old Oct 22, 2001 | 09:21 PM
VMAX451's Avatar
VMAX451
This has happened to me a few times too... Try to pull into traffic briskly only to have the ASR kick in obtrusively (not trying to burn rubber, just hitting a bump while accelerating a little more than usual) and you're stuck staring at traffic barreling towards you while you're helplessly immobilized for a few seconds. They may have improved the sensitivity in later years, but on my '92 it just doesn't work all that well under some circumstances.
[Modified by Vince Ivanc, 8:22 PM 10/22/2001]
*EDIT x 2* I need to learn how to friggin' type! :rolleyes:
[Modified by Vince Ivanc, 8:23 PM 10/22/2001]
Old Oct 22, 2001 | 09:23 PM
GS 163's Avatar
GS 163
Turn mine off all the time.:)
Old Oct 22, 2001 | 09:25 PM
Guest
Guest
Posts: n/a
Default Re: ASR Question (JPLT1)
I'm going to turn it off tomorrow a.m. on the way to work. Any special instructions? Like the car has to be at a stop, that sort of thing?
Old Oct 22, 2001 | 09:27 PM
GS 163's Avatar
GS 163
Just push the button. A light on the dash will say ASR off. Then you punch it and away you go!:D
Old Oct 22, 2001 | 09:30 PM
Guest
Guest
Posts: n/a
I'm going out to try it right now.
Old Oct 22, 2001 | 09:43 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'm not positive on this, but I'm pretty sure in '95 it became an instant on/instant off deal, don't know if it's true for all years or what year it started.
Old Oct 22, 2001 | 09:48 PM
Guest
Guest
Posts: n/a
Okay, I noticed a difference...but it may be my imagination - quicker. Funner to drive, for sure. :reddevil
Old Oct 22, 2001 | 10:35 PM
GS687's Avatar
GS687
Mairi,
Usually, if ASR activates, you will feel a sudden and hard push from the accelator as it pushes your foot off of the floor, so you will know when it "kicks in." Keep in mind that the system was designed to aid in preventing the car from getting ahead of you in aggressive driving (sometimes known as tail lights first). Under some conditons, with 300 HP, it isn't too difficult to lose control of the rear end with the ASR off. Be careful!
Old Oct 22, 2001 | 11:01 PM
Snowblind's Avatar
Snowblind
Default Re: ASR Question (GS687)
There is also an audible sound that comes from somewhere when ASR comes on.
Get this, the loudest it ever came on was when I let my brother take it for a drive. He made a 90 degree left hand turn into a subdivision without ever slowing down or touching the brakes.
Does anyone know about the sound. It seems to me like it is supposed to tell you ASR has activated and some sort of degree of activation, based upon sound.
FYI I leave mine on almost all the time, but I do understand the guys that do not like it. Hitting a bump under acceleration will cause it to activate, sometimes when you need to keep accelerating!
Old Oct 22, 2001 | 11:08 PM
Guest
Guest
Posts: n/a
Default Re: ASR Question (Snowblind)
Okay, so let me get this straight: This is something that is "on call" for lack of a better phrase.... not making a difference one way or another under normal driving conditions. I know I am not using the correct term here, but can it be likened to positraction? Maybe it never has been activated on me. I'd like it to so that I know. Sounds like I let my imagination run away with my mind when I tried it "off" a while ago.
Thanks much for your input.
To ASR Question
Old Oct 22, 2001 | 11:49 PM
GS 163's Avatar
GS 163
Do this. Pull up to a stop light or somewhere with it on. Roll away from a dead stop and then nail it. The ASR should kick on and bog down the motor. Then turn it off and do the same thing. It should spin the tires pretty good. At least it does in mine. Let us know what you come up with.:)
Old Oct 22, 2001 | 11:55 PM
GS687's Avatar
GS687
Yep, you're right, it's dormant until wheel spin is detected and when it senses spin(slippage) outside of the computer's acceptable levels, it intervenes.
Here's a way to feel it "Kick In". In a vacant parking lot, start out with full throttle and turn left hard while you have the throttle planted on the floor. You will feel the acceleration immediately retarded as "ASR" feels slippage and activates and your accelerator foot will be pushed off of the floor. It won't require much speed, just an abrupt, unsettling move and weight shift.
Good Luck!
VMAX451's Avatar
VMAX451
When it's in action, a light on the "DIC" should come on too, something like "ASR active". Sometimes you only get the ignition retarded, so the light is the only giveaway, but usually the gas pedal fighting back and brake controller buzzing away leave no doubt.
[Modified by Vince Ivanc, 10:56 PM 10/22/2001]
