Enough procrastination...headers are going in
Old May 25, 2007 | 08:21 AM
mdlfcrss's Avatar
mdlfcrss
Default Enough procrastination...headers are going in
Well, after 6 months of making excuses, I finally decided to put the headers in my '91. I'm putting in Hedman Elite's which ARE ceramic coated by the way (so we can put that issue to bed!). I just finished the drivers side last night and can't figure out what to do with the alternator bracket. Does anyone have any experience with this problem...if so, what did you do?
The passenger side doesn't look like it's going to be any picnic, but fortunately it's not my daily driver, so I'm not in a hurry to get it done. I know the A/C bracket needs to be modified as well but they show you what to do on Hedmans website.
ps... got the car up on jackstands, pulled the y-pipe, removed the drivers side manifold and got the header in in just over two hours, not bad for an old guy, huh?
Old May 25, 2007 | 09:19 AM
RacerX70CC's Avatar
RacerX70CC
Build a spacer or delete the brace... those are your choices (it's not rocket science)
RACE ON!!
Old May 25, 2007 | 10:04 AM
mdlfcrss's Avatar
mdlfcrss
Thanks Captain Obvious... I had that much figured out already.
Old May 25, 2007 | 11:41 AM
RacerX70CC's Avatar
RacerX70CC
My mistake... I thought you asked what to do...
FYI, on the passenger side.. pull the motor mount bolt out and put it in from the other side (one of the tubes usually hits it).
Old May 25, 2007 | 11:49 AM
torchred89's Avatar
torchred89
I put TPIS long tub headers on my 89 and I never put headers on that was so easy and everything went together perfect including heated O2 senser
Old May 25, 2007 | 12:07 PM
Aardwolf's Avatar
Aardwolf
I saved a picture of a bracket a forum member made, it was posted a long time ago now and I do not remember who. Here is the image though:
Old May 25, 2007 | 01:56 PM
mdlfcrss's Avatar
mdlfcrss
Thanks for the picture, Aardwolf. I'll print it and bring it home with me tonight...maybe it will help.
Old May 26, 2007 | 08:16 PM
f451degrees's Avatar
f451degrees
are you going to do the air elimn.? or did you get the headers with the air tubes. I ask because I'll be doing mine soon and need to make up my mind.
thanks
tom
Old May 27, 2007 | 08:53 AM
sonomacrew01's Avatar
sonomacrew01
I thought that little tube was usless. As soon as I tightened the header bolt, the tube would kink. So I modified the brackets to fit flush against the header flange and welded the outside bracket to the inside bracket.
To Enough procrastination...headers are going in
