Jacking
Old May 25, 2007 | 08:29 PM
skirby's Avatar
skirby
Default Jacking
Hey All,
Is there a special jack for the C4 (96)?
My car came used with the spare but no Jack. Can I use one that I had from an old Ranger? I also have a floor jack but I am afraid of using it for fear of damaging the body/underparts. Where do I put it to lift the car and is it safe to do in a home garage?
Any info is appreciated.
Old May 25, 2007 | 08:55 PM
bogus's Avatar
bogus
www.c4guru.com - Jacking and Towing
Your floor jack should be a-ok.
Old May 26, 2007 | 08:48 AM
Wayne88's Avatar
Wayne88
Originally Posted by skirby
Hey All,
Like the above article shows, jacking is easy on a C4.
Look underneath the car and familiarize yourself with the frame.
I never use the Gm jack to jack my C4. But if you want a stock jack, you can probably get one from forum vendor vette2vette. He runs a Corvette salvage yard.
http://www.vette2vette.com/
Old May 26, 2007 | 09:57 AM
rws.1's Avatar
rws.1
get an E-Z Jack adapter to lift both rear wheels at the same time
http://www.corvettegadgetman.com/
Old May 26, 2007 | 10:26 AM
Daddy J's Avatar
Daddy J
The foregoing replys have given you good info. You might also want to take a look at http://www.zr1registry.com/ On the left hand menu click on "maintenance" and another menu will appear below this. Click on "ZR-1 How to" and then scroll down the page to "How to Jack Up a ZR-1. by Michael Hom" - Lots of pictures and also mentions using a hockey puck on top of your floor jack which I found was a great idea. One of the replys mentioned the E-Z Jack adapter which works great too.
Old May 26, 2007 | 10:38 AM
rws.1's Avatar
rws.1
The jacking article cited by Michael is how I jack the front and the rear before I got the EZ- jack and where I place jack stands
Old May 26, 2007 | 02:16 PM
ourblk96's Avatar
ourblk96
Hey All,
I have a 96,too. I'm not trying to be a smart a__ but look behind the drivers seat on the floor this is where I found my jack.
Don
Old May 26, 2007 | 03:58 PM
Dads90's Avatar
Dads90
Don
I only have the lug wrench behind my seat. My jack is in a bag within the spare tire.
Old May 26, 2007 | 04:01 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
If your jack was behind the drivers seat on the floor, then somebody moved it there. From the factory, 1996 jacks were installed in the storage compartment behind the passenger seat. The lug nut wrench was bolted down behind the drivers seat.
Old Oct 5, 2007 | 08:27 PM
Motsiv2's Avatar
Motsiv2
Floor jacks work good. But, I have to ride up on 2 by 10 boards to get clearance for the jack under the front end. I usaully place the jack under the crossbar by the transmission.
Old Oct 7, 2007 | 04:52 AM
84-2thefloor's Avatar
84-2thefloor
I like the nice spot under the hood for my things There is nothing like riding in a Corvette on a donut lol. Best of luck to you finding everything.
Old Oct 7, 2007 | 05:49 AM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
The Jack for my '94 is in the same place, always has. Look under the storage bin tray inside the compartment behind the passenger side seat. This is where your Bose radio reciever should be located as well.
Old Oct 7, 2007 | 08:31 AM
Billy Stargazer's Avatar
Billy Stargazer
I found that to be a problem also. I then found an aluminum Craftsman floor jack that has a clearance of only 2". It works like a charm although it cost almost $200. Only about 3 or 4 pumps and vioalla, your car is raised almost 16". Money well spent, in my opinion.
To Jacking
