Headliner
Old May 30, 2007 | 05:57 PM
ballertyped's Avatar
ballertyped
Default Headliner
Sorry I am flooding you guys with questions, how do I remove headliner?
Is it just glued to the top (1995)???
Old May 30, 2007 | 06:58 PM
jojo88C4's Avatar
jojo88C4
mine was just glued in, in my 88.. just replaced mine, cost me less than $20
Old May 30, 2007 | 07:11 PM
Wheelman's Avatar
Wheelman
Did you reuse the greenish foam backing board? Mine looks similar to yours and emits a flaky dust if I touch it. I am also curious what you used to reinstall it with.
Old May 30, 2007 | 08:40 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Do NOT take out the fiberglass batting, you will destroy it. Carefully remove the foam backed uphostery and try to get as much of the old foam and glue off the batting, and then install the new headliner material using the 3M SUPER spray or the equivilant. Regular duty adhesive will fail in a few months to a year, especially in areas like Arizona. Early 80's used a white styrofoam backing that was velcroed on, but I think that ended in 87-8. Yes you reuse the "greenish foam backing".
Old May 30, 2007 | 08:42 PM
Wheelman's Avatar
Wheelman
Too late. Mine came out all in one piece. Any hope for gluing this green stuff back in?
Old May 30, 2007 | 08:44 PM
zr1fred's Avatar
zr1fred
Very lucky! Just glue it up with contact cement.
To Headliner
