11" wheels on front
Old Jun 1, 2007 | 12:40 PM
xluke's Avatar
xluke
2nd Gear
Default 11" wheels on front
Hello,
I was wondering if I can put stock 17x 11" wheels (that are normally on the rear) on the front of a '94 corvette w/o having any clearance/rubbing issues. Is an adapter plate or anything similar required?
Thanks a lot!
Old Jun 1, 2007 | 01:54 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
You can run the GS offset ones with minor rubbing issues at full lock.
Old Jun 1, 2007 | 02:29 PM
90 Corvette ZR-1's Avatar
90 Corvette ZR-1
I've thought about this, but I can't find a decent set of 335s for the rear
Old Jun 1, 2007 | 07:39 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I run 12's up front when I autocross. Offset is the key.
335's can be had, but you really need to go to a 12in wide rim.
Old Jun 5, 2007 | 03:00 PM
xluke's Avatar
xluke
2nd Gear
Can you run zr-1 11" wheels up front? I think the offset is 50mm...
Thanks!
Old Jun 6, 2007 | 03:51 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
1) 11" wheels aren't NORMALLY on the rear of a 94 vette. However, they are on GS and ZR1 cars. If you have an LT1 vette, your rears are 17x9.5 and they will work on all 4 corners.
2) 11" wheels work fine on the rear of all C4s -- though early models won't protrude (because their axle/hub is recessed more). When they went to bigger brakes in mid-88, the offset and wheelsize had to change.
3) 11" wheels don't work well on the front of most C4s if they are the ZR1 offset. Depending on the state of your front transverse leaf spring, you would rub on big bumps (like speed bumps) where the car bounces a lot. (I tried ZR1 offset 11" on my fronts to prove this). However, the rubbing was very minor and wouldn't occur with less offset. I really think GS offset 11" wheels would work fine (unless you're suspension is drooping). The offset is reduced just enough to eliminate with the rubbing.
4) ZR1 wheels are ZR1 wheels. (They have the ZR1 offset). ZR1 "style" wheels (aka A-molds/5-spoke) are available is GS/ZR1 offset.
Old Jun 7, 2007 | 02:07 PM
VIN_#_00521__Z-51_C4's Avatar
I have an '84 and when I bought it the 2nd owner put 17x11" ZR-1 replica wheels and 315/35"s out back They look really nice
To 11" wheels on front
