Quick ? about A/C
No where's in any of the directions does it say anything about this. I would just rather be safe than accidently overfill something.
TIA
To force your compressor to engage you need to short the wires on the low pressure side switch. Remove the connector, using a paper clip and put it into the connector holes. You normally don't want to do this because exactly as it says "It a low pressure switch". If you have low pressure it will shut off the compressor so you don't burn it up. So, you jump it only when loading freon into your car. When shorted your guage will show the correct reading. If the compressor isn't turning whatever the guage says doesn't mean $hit.
Lastly for some reason when most people retro there R12 to R134 they fail to use a retro low pressure switch. Yes, the pressures are different from R12 and R134. Here is a link and a pic of the retro switch... http://www.fjcinc.com/pdf/2007catalog.pdf (page 61)
Seems Risky? yea, but that's the way every AC guy does it... Just trying to help you.... Go ahead and continue your way if you want.... Miracles do happen sometimes...
I wish it would get that cold in the daytime when the sun's beaming down inside the acrylic top. No complaints though after going two year's without a/c and heat it's all good.
Weak to me means shot. If your compressor comes apart while it's running, you will never have trouble free air conditioning again as long as that car is in existence. The compressor will fill your system with metal particles, and trash. That trash will shortly wipe out another compressor, clog your expansion orifice, plug up your evaporator and condensor, and render the system inefficient.
R12 does run colder than the R134a
R12 is the best! There is nothing better!
If you need more R12, then goto www.epatest.com and pay your $25 and get your license. Then goto Ebay and buy as much R12 as you need.
If you must change to R134, then you need to flush the system, replace the accumulator, replace the orfice tube, replace all the rubber "O" rings, pull a vacuum, replace the low pressure switch, and load the freon. The 1st time you do it... it's hard, the second time is extremely quick.
Remember, if for some reason you get a wild hair up your a$$ and want to convert to R134 because you don't want to buy the license for R12, then most car repair places will usually suck it out for free. They sell the R12 to reclaimer, who will reprocess it again and sell it. They make alot of money by just connecting hoses to your car. That's why they usually do it for free.
