Caugh, Sputter, ROAR!!!!!
Old Jun 5, 2007 | 11:49 AM
jhammons01's Avatar
jhammons01
Default Caugh, Sputter, ROAR!!!!!
I was posting in another thread about an issue I've been having. But the thread jack is not appreciated.
I have stock 1984
If I sit at a red light for a bit, When I start to let the clutch go if the RPMs drop the motor coughs, spits, sputters and then off it goes as if there was never a problem. Shift into 2nd and it runs fine even though I sometimes short shift and hit those same low RPMs. Same thing throughout all the gears from there on up.
If I am thinking about it I'll rev the motor a couple of times prior to the Light changing and then let the clutch out and it runs fine.
I was thinking fuel delivery problem but others (CentralCoaster) posted other symptoms would lead to the fuel pump.
So, to sum it up, sitting at red light/idling let the RPMs drop and it coughs.
Can you guys give me some suggestions?
*edit*
I hate how you can't edit the title........"Cough"
Old Jun 5, 2007 | 02:12 PM
N.C. Kid's Avatar
N.C. Kid
I have stock 1984
Codes?
Old Jun 5, 2007 | 03:26 PM
jhammons01's Avatar
jhammons01
No codes pulled yet.
Old Jun 6, 2007 | 10:16 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
When's the last time you changed your plugs, wires (including coil wire) and plug wire holders?
Open your hood at night at take a close look. You might have electrical arcing (engine misfire) going on.
It gets hotter'n hell under that clamshell hood and Corvette plug wires take a beating.
Old Jun 6, 2007 | 07:54 PM
Sprint7677's Avatar
Sprint7677
Clean your IAC's
Check the TPS voltage
Old Jun 7, 2007 | 01:54 AM
jhammons01's Avatar
jhammons01
here it is.
Started digging into it a bit further once I saw nobody posted an obvious.
The Plug wire on the passenger side was burned. They are three months old and it was burned inside the boot. White Chalky stuff all inside and the boot itself cracked when I was examining it. The White Chalky stuff was even forming between the Shielding and the Rubber Hood Gasket above the Distributor. So this thing has been arcing under there for some time.
The Good is that I took it back to Kragen and they upgraded me to the Borg Warner 8.5 Wires under warranty. These wires had a two year warranty but the better ones have a lifetime warranty.
onedef92 and Kragen did me right.
Old Jun 7, 2007 | 01:56 AM
jhammons01's Avatar
jhammons01
I have to ask one question.
(and it is the type of question that gets you beat up after school for asking it)
There is no Coil under there. There is no coil wire. I can't find it, am I missing something?
I like to think I'm pretty handy, but I have looked numerous extensive times. I can't find it.
Old Jun 7, 2007 | 11:00 AM
onedef92's Avatar
onedef92
On my LT1 it's located on the passenger side of the engine near the PS fluid resovoir. The photo shows the coil. The coil wire fastens onto the connector.
http://www.autopartswarehouse.com/bi...+Corvette+Coil
To Caugh, Sputter, ROAR!!!!!
