Spark Plug wire Help
Old Jun 8, 2007 | 12:55 AM
jhammons01's Avatar
jhammons01
Default Spark Plug wire Help
Quick question for you Gurus. I was telling you about the Cough spudder problem.
I got another set of Plug wires, this time the same thing. 7 wires with 90° boots on either end.
Then there is one Wire that has one 90° boot and then a long boot with a slight bend in it. This is the wire that I thought was a Coil wire.
My question is this, This long boot must go to one of the Plugs that is hard to reach or that is close to the Exhaust or something similar to that.
Do you guys know which Plug it goes on? I would follow the old set but it didn't have this configuration so I am kinda stuck.
Old Jun 8, 2007 | 01:08 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I believe it goes on #6
Old Jun 8, 2007 | 01:30 AM
C4boy's Avatar
C4boy
I think #6 is where I put mine, too. I know it's on the right bank. On my '86, I was thinking it's because the wire is right next to the EGR tube.
Old Jun 8, 2007 | 02:10 AM
jhammons01's Avatar
jhammons01
#6? Right side?? Passenger or Driver side? and do you count from the front back? 2, 4, 6, 8, and 1, 3, 5, 7?
I'll probably get beat up everyday for a week for asking that one.
That's alright, I appreciate you guys helping me out.
Old Jun 8, 2007 | 02:26 AM
C4boy's Avatar
C4boy
When Right and left is referred to, it's always while sitting in the car. Right is passenger, left driver ('cept for the guys on Oz ).
Odd # cylinders are all on driver's side, even on passenger. # 1 is the left front cylinder, #2 is Right front, #3 is the cylinder right behind #1. They are numbered left to right, front to back.
Old Jun 8, 2007 | 02:34 AM
jhammons01's Avatar
jhammons01
OK with that, The #6 cylinder is where the old wire burned, so that makes perfect sense. Maybe that Plug is too close to an exhaust manifold or something. All I know is that trying to put a 90° boot on that plug is really difficult.
I'll try the straight boot on that plug and see how it fits.
thank you.
Old Jun 8, 2007 | 02:41 AM
C4boy's Avatar
C4boy
Old Jun 8, 2007 | 11:54 AM
jhammons01's Avatar
jhammons01
Thanks again
Old Jun 8, 2007 | 02:24 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Always do your plug wires one at a time so you don't skew the firing order.
Old Jun 8, 2007 | 03:43 PM
jhammons01's Avatar
jhammons01
Originally Posted by onedef92
Always do your plug wires one at a time do you don't skew the firing order.
absolutely. That is why I have no idea of Firing order etc. If you only do one at a time why worry which is which and which wire goes where on the distributor Cap.
Learned that one in 1978
To Spark Plug wire Help
