Weatherstrip Help
Old Jun 8, 2007 | 02:45 PM
ballertyped's Avatar
ballertyped
Default Weatherstrip Help
I just need to know what to use to clean old weatherstrip glue and what kind of adhesive to put the new rear hatch weatherstripping on my 1995 coupe, please...
Old Jun 8, 2007 | 02:58 PM
ballertyped
Anyone???
ballertyped
Anyone???
Old Jun 8, 2007 | 03:26 PM
msslp04's Avatar
msslp04
St. Jude Donor '11,'14
Use 3M adhesive remover to get it out. Clean it up good. Use 3M weatherstrip adhesive (black) to tack it back down.
Kevin
Old Jun 8, 2007 | 03:27 PM
ballertyped
you da man...
Old Jun 8, 2007 | 04:59 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
If the weatherstrip on your hatch is the factory installed one, there is no adhesive. It's a grease that's used a a lube for install and it's messy as can be. I didn't use any chemicals to remove it just a lot of shop towels. I installed the new weatherstrip without any sealent and it has no leaks.
Old Jun 8, 2007 | 08:55 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Kevin
I agree, I used the same products, and was very happy with the end result!
Old Jun 8, 2007 | 09:15 PM
VolMan's Avatar
VolMan
Default I am doing mine too
The posts here match the research I did on this topic.
The Helms manual lays out the procedure to remove and replace.
Yes, remove the old glue if there. Mine currently has the yellow glue. It looks terrible. One member calls the yellow glue "gorilla snot", Funny.
Leave the new weather stripping in the sun for a few minutes to get it loose.
Now, I am using a product from Corvette Rubber via a Corvette parts supplier here in Atlanta. I see some references that Corvette Rubber and Willcox are one and the same, but I cannot confirm.
I saw the price difference, so I went with the Corvette Rubber piece. I wanted to this job this weekend and the shop was out of the GM weatherstrip.
I have heard good and bad on both the GM and the others. Shall see how it goes. What are you using up there in Canada?
I am told the job does not take long to do. My luck, I will find a way to make it a long job.
Anyway, the current strip (on when I bought the car) has a huge gap in the corner, yellow glue shows. So, what I am doing is an improvement.
I read to go with the corners first. Ensure its all even before placing it on.
Good luck.
Doing this, changing the oil, will try to se if clay bar helps the paint on the hood. Lots of little brown spots that dont wash or polish off. It feels smooth to the touch.
Old Jun 8, 2007 | 10:16 PM
ballertyped
Be careful the rear window struts are a pain, watch it...
Sealed my rear window nice! thanks
Old Jun 9, 2007 | 02:09 PM
skybolt31's Avatar
skybolt31
I agree, mine had a piece of weatherstripping that at one time early on in its life had a piece of channel attached to it. When I got the car, they were two separate pieces, so I removed them both and didn't clean any glue off and didn't add any glue, just pressed the channel on the new piece over the lip and was done.
To Weatherstrip Help
