Found Something While Changing The Oil...
Old Jun 8, 2007 | 03:25 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
Default Found Something While Changing The Oil...
I was changing the oil on the 91 with the 383. The engine has about 7500 miles on it. When I pulled the magnetic oil plug there was a teenie tiny piece of smashed metal about 1/16" by 1/8" long. I was going to take a picture of it but it started to rain and a raindrop knocked it into the gravel. How about some feedback? Anything to be concerned about? Or just wait till something breaks and fix it then.
Old Jun 8, 2007 | 03:41 PM
Pete K's Avatar
Pete K
That is one of the problems with a magnetic plug. Every time they do there job, we panic. It could be anything, but it is likely nothing. It could be a piece of debris that was in the filter(left over from manufacturing). Quite possible it did not come from the motor until the filter put it there. I know it sounds odd, but happens more than you think.
Old Jun 8, 2007 | 03:44 PM
Tommy T-Bone
Thanks Pete. I feel better already.
Old Jun 8, 2007 | 03:46 PM
Pete K's Avatar
Pete K
I had the same thing happen, but with bigger peices of debris. Never a problem
Old Jun 8, 2007 | 04:22 PM
Goldcylon's Avatar
Goldcylon
A small amount of wear is normal. Its entirely possible that a larger piece all the way back from the block casting days finally broke free. The good news story is the magnetic plug picked up that little bugger before it could go somewhere else and cause hate and discontent.
Old Jun 8, 2007 | 05:08 PM
carlton_fritz's Avatar
carlton_fritz
St. Jude Donor '08-'09
I'm inclined to believe a guy in the 10 second club.
Old Jun 8, 2007 | 06:25 PM
jdeatsch's Avatar
jdeatsch
Default elementary my dear Watson...
Let's think this through.
If the magnet captured it then it wasn't piston parts, whew.
Bearing material? Certainly not valve stuff. Doubtful if it's a piece of ring.
I'm voting for bearing edge material.
Sounds to me like the mag plug did it's job, yep yep.
Jim
Old Jun 8, 2007 | 06:31 PM
JackDidley's Avatar
JackDidley
If its anything that matters, it will be valvetrain. If you are really concerned, pull the valve covers and have a close look at the springs. Its probably nothing though.
Old Jun 8, 2007 | 06:32 PM
chucks88's Avatar
chucks88
I had a large enough chunk that wouldn't escape the drain hole in my oil pan for the longest time. After I tore the engine down(for another reason) I discovered it was a piece of one of my piston skirts. Car seemingly ran fine with it in there.
Old Jun 8, 2007 | 06:58 PM
Pete K's Avatar
Pete K
That seems to happen quite a bit. I have torn a few down and found skirts in the pan.
Old Jun 8, 2007 | 07:26 PM
Happydad's Avatar
Happydad
Hey Pete Something Like This I had 5 of them like that...cashed the engine and built a 350+ new block up
Old Jun 8, 2007 | 08:02 PM
Pete K's Avatar
Pete K
Yep. The odd thing is that the motors seem to run well in spite of the skirts breaking off.
Old Jun 8, 2007 | 08:32 PM
90Indy's Avatar
90Indy
The only thing to do is look on the bright side - less metal means less weight - less weight means quicker et.
All kidding aside I feel your pain. If you are really concerned you could have the oil analyzed but I wouldn't worry about it.
90Indy
Old Jun 8, 2007 | 10:21 PM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
I have seen posts where people have found pin bearings from their valve train on their magnetic plug.
Old Jun 9, 2007 | 12:13 AM
Arkybill's Avatar
Arkybill
I've run Oberg (or that type) of oil filters on everything (except this vette) for the last 30 years. It's unblievieable what you find everytime you change the oil and clean the filter. Bits of bearings, little chunks of steel, fine hard granules of carbon, pieces of alumium (skirts).
Change the rocker covers gaskets and the bypass light comes on in about 45 seconds after you start it up the 1st time. sometimes it takes 2 or 3 cleanings to get the bypass light to stay off for 100 miles. Seems scarey, but, you get used to it. Don't mean anything. Unless you gots stuff coming apart. How do you know the diff- well, the engine makes funny sounds and lotsa smoke-then quits.
Sometimes it's best if you just don't know what floating around in the oil.
To Found Something While Changing The Oil...
