Loose Side Mirror
Old Jun 11, 2007 | 10:29 PM
csc67's Avatar
csc67
Default Loose Side Mirror
The driver side outside mirror is lose and rattling back and forth - How to I tighten this
Chris
Old Jun 11, 2007 | 10:36 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Take your door panel off, if you haven't done that before. Take your time, and if it is sticking... look very close for a screw. A lot of people have broken theirs by not seeing some of the screws. Then roll your window down all the way. From there you should be able to reach the 2 bolts that hold it on
Old Jun 11, 2007 | 10:48 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
If it's just the mirror in the housing, there are two "pins" that pop into holes on the back side of the mirror and a center x piece that pops into place on yhr back.
Old Jun 11, 2007 | 10:53 PM
1990Redcoupe's Avatar
1990Redcoupe
If its just the glass itself that is loose it likely to be a broken trunion between the mirror and the mirror positioner. Just go to any self serve junkyard and find a late 80s Camaro with broken mirrors. They seem to use the same trunion.
Remove the old one, snap in the new one into the positioner then place the mirror over the other side of the trunion and push inwards. it should snap into place and the mirror will be secure.
While the mirror is off the car you may want to tighten up the positioner mounts as well. It takes very little time once the mirror is out of the way.
Old Jun 11, 2007 | 10:58 PM
csc67's Avatar
csc67
It is just the mirror glass that is loose
To Loose Side Mirror
