Holy lugnut torque specs!!!
Oct 25, 2001 | 07:23 PM
Ok, I always torque my lugnuts to 100 ft/lb religiously. In fact I do it in three stages.... 50, then 75, then 100.
I just happened to be thumbing through a spare '87 owners manual and just saw that it is 80 ft/lb.
Crappola!!!
What does everyone else do? :confused:
Oct 25, 2001 | 07:54 PM
Re: Holy lugnut torque specs!!! (scorp508)
I tighten 'em till they feel tight enough, using a 4 axis (x shaped) all purpose lug wrench. I do tighten in stages crossing the centercap.
Bob
Oct 25, 2001 | 08:15 PM
Re: Holy lugnut torque specs!!! (BobMachus)
I do 90 ft/lbs.
Tom Melton
82 CE
86 Z51 Coupe
Oct 25, 2001 | 08:25 PM
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
100lbs here :)
Oct 25, 2001 | 08:28 PM
When they feel tight enough, one quarter turn past that.
Oct 25, 2001 | 08:45 PM
Re: Holy lugnut torque specs!!! (Smash)
I could swear that it said 100 in the manuals for both the 86 and 96...
Oct 25, 2001 | 08:47 PM
I just use the machine and go until it does "proooo... tak tak tak tak"... basically when it stops spinning.
Oct 25, 2001 | 08:49 PM
Re: Holy lugnut torque specs!!! (rcolling)
I'll scan it if you'd like. :) ;)
Oct 25, 2001 | 09:06 PM
If your owners manual or GM shop manual says 80 then go with it.
better safe than sorry.
Oct 25, 2001 | 09:36 PM
What does the Helms say?
My guess is that it says 100. You can probably get away with 90-95 though. :)
Oct 25, 2001 | 10:41 PM
Re: Holy lugnut torque specs!!! (JasonL)
Run 'em on with the impact in a cross pattern until they just pull the wheel against the rotor then torque in a cross pattern to 100 ftlbs. My Helms and Chiltons both say 100.
Oct 25, 2001 | 11:37 PM
So Scorp, how did you manage to get points deducted?
Oct 25, 2001 | 11:38 PM
Re: Holy lugnut torque specs!!! (L98FIRE)
This should cover it....
http://forums.corvetteforum.com/zerothread?id=172891
Oct 25, 2001 | 11:47 PM
Torque mine to 100.:)
Oct 26, 2001 | 02:59 AM
My aftermarket Enkei's call for 75 lb ft...however, I like "Tight" much more that "click".
Oct 26, 2001 | 06:43 AM
Re: Holy lugnut torque specs!!! (C4 Suke)
:lol: :lol: I think we use the same manual.
Oct 26, 2001 | 08:48 AM
Cruise-In III Veteran
Torgue to 75 lbs on mine. My tire guy has had customers break the studs when over tight and they hit a pot hole (thats what we call a lack of maintenance to the street down south)
:cheers:
Oct 26, 2001 | 09:43 AM
80# here. And that's in the service manual, too.
Oct 26, 2001 | 12:16 PM
Re: Holy lugnut torque specs!!! (CowboyNVette)
i usually turn it until i hear that little noise. a few clicks or pops :chevy
Oct 26, 2001 | 01:31 PM
Well, I just purchased new ZR1 rims and the spec is 75 - 85 ft lbs. I do mine to 85 ft lbs. A service manual I have states the same thing. :cool:
