When doing weatherstripping
Was not sure if they needed some seal behind the metal or not since the new weather strips will be in place shortly.
I just got my wilcox kit out and I am looking to figure out which piece goes where now and I see that I have no new screws or plastic pieces. Do the new kits not use those plastic supports like the stock units?
Mine were dried and mostly fell apart when I took them off. I could locate some newer sheet metal screws in the garage or try to locate some stainless steel units at the hardware store if I need them.
I would have thought this kit would have had those plastic supports.
Edit:
I just took my outer strips out of the package they came in...no new screws? I guess the stock ones are reused? I had read that they used rivets from the factory though.
