A/C compressor not cycling
Car is a 1986 with a Delphi compressor in it (model 4346) installed by the previous owner. I cross checked the compressor number and it is for a 1992 Chevy pickup. I have owned the car for two years and the system worked properly (compressor, blower, fan), it didn't blow very cold but did a good job defogging the windshield.
I just had the system evac'd and recharged with Freeze 12 (looking for a temporary fix). The mechanic said the system was not leaking, pressure was good, and the vent temp was around 50 degrees. Soon after I left the compressor quit working. The compressor doesn't cycle at all when I hit the A/C. The blower comes on and blows air out the vents. The aux fan is also engaging when I engage the A/C. Going through the previous owner's receipts he replaced the control module in 2000.
After researching threads I disconnected the battery cable to reset computer (for 10 min). This did not solve the problem.
- Low pressure switch reads 5.11v
- Jumping the LPS with a paper clip did not engage compressor
- Voltage at the compressor switch harness is 5.5v
- I get no voltage reading at the compressor switch terminals when the harness is plugged in.
Is my compressor shot?
Remove the connector and check resistance across the low pressure switch contacts. If it's open, either your non leaking system developed a leak, or the switch is bad. Only way to tell would be with a manifold gage set and it isn't a great idea to try and jumper the harness if those switch contacts are open.
I'm assuming - by your voltage at the Low Pressure Switch - that this is Electronic Air. If so, the compressor is grounded by the Blower module as long as the Low Pressure and High Pressure Switch contacts are closed. Always a possibility that the High Pressure Switch opened because mixing gases can lead to extremely high pressures. Circuit though is through the High Pressure Switch and then onto the Low Pressure Switch, so if you have voltage at the Low Pressure Switch, the other is closed. And as long as that circuit is completed, the Control Panel sends the "on" signal to the Blower Molule which then grounds the compressor, so follow the lead from the compressor to the module and jumper it to ground. The clutch should engage. If it does, you probably need a new module, though the Dash also likes to see a completed ECM circuit - that runs from the Panel to Pin B7 at the ECM and it should have 5 or so volts on it when the a/c is requested, so you could check that before running out and buying a new module.
Your Year only communicates with the ECM for idle and WOT control and the few troublecodes (there's none for low or no gas) that can be stored within the Processor (dash controls) will not prevent the a/c from running. So disconnecting and reconnecting the battery or removing memory power from the dash isn't necessary, but it doesn't hurt anything.
