84 a/c problem
Old Jun 16, 2007 | 02:24 PM
pablo84's Avatar
pablo84
Default 84 a/c problem
My 84 control unit is stuck on one mode. When I slide to max, normal, heater, defrost, it blows from all of them, at once. Any ideas? Thanks in advance for your help.
Old Jun 16, 2007 | 10:32 PM
Droshki's Avatar
Droshki
My 85 did the same thing when I got it. I found that the main vacuum line that goes from the engine to the AC/Heat control unit in the dash was not connected/broken. Apparently this is the default *stupid* mode.
The line is hard plastic, starts on the passenger side of the intake and goes into the wiring harness onto its way to the interior. Instead of trying to deal with all of that, I just just drilled a little hole in the firewall and ran a new line. I checked this to be sure, beforehand, by running a long vaccum line from the engine in through the open door to the control head to be sure that would fix the problem, and when it did, I just popped the new line in like I described above.
I think you will go down a very similar path. While it could be the control head itself, I doubt it. Pop the control head out. Check for vacuum on the main line from the engine...its the black one thats seperate from all the rest of them. No vacuum? You know what to do...
Old Jun 19, 2007 | 10:50 AM
pablo84's Avatar
pablo84
Thanks for the info. I did just what you said and it worked!!
To 84 a/c problem
