Understanding cam specs
Old Jun 20, 2007 | 06:29 PM
jimmers's Avatar
jimmers
Default Understanding cam specs
I'm reading over the specs of my car and am wondering about the cam. I know that everyone always talks about lift and duration, but I have different specs for intake and exhaust. What is the difference, and if someone asks me the lift and duration what do I say. The reason I'm asking is because I believe I need to get my chip reprogrammed. The car is running very rich at idle. Thanks for the help!
Heres the link to the specs.
http://www.compcams.com/Technical/Se...umber=08-501-8
Old Jun 20, 2007 | 06:48 PM
vader86's Avatar
vader86
You usually answer by giving the duration @050", and the lift at .500"
Old Jun 20, 2007 | 07:06 PM
cv67's Avatar
cv67
St. Jude Donor '05
Engine -Present Chevrolet
305ci-350ci
8cyl.
Grind Number CS XR264HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.488 0.495 Total amount valve is raised off the seat
Duration At 0.006 Tappet Lift 264 269 AKA Advertised duration
Valve Timing At 0.006
Open Close
Intake 24 60
Exhaust 70 18
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 212 218 AKA duration @.050
Lobe Lift 0.325 0.33 Take this # and multiply is by 1.5 (1.5 rockers), should get your total lift noted above. Using 1.6 rockers? Do the same. Lobe Separation 112
Also, a factor called "intensity", simply put a way to see how agressivethe ramps and valve events are.
Ex: Take the adv. duration, say 280
minus-
dration @ .050, say 230
an intensity factor of 50. They say 48 is pretty damn decent...Lower the number the more agressive the ramp for the most part. Fwiw, less intensity typically are gentler on valvetrain parts and may last longer.....+ and -
My solid roller has an I.F. of 30. Ramps are inverted
Camspeak can get much more technical to the point where I get lost, but these are some basic regurgitated things youll read about a lot. I used to hang out on a Chevelle site where UD Harold, designer of the Lunati Voodoo line is a lot, and some of the discussions would leave me stupified.
Old Jun 20, 2007 | 07:18 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I don't understand this. The lift is what the lift is. There's a lift spec measured at the cam, total valve lift for a given rocker ratio, etc. But measuring the lift at .500" what?
Old Jun 20, 2007 | 08:45 PM
jimmers's Avatar
jimmers
Thanks!
Old Jun 20, 2007 | 09:41 PM
jimmers's Avatar
jimmers
minus-
Thanks for the explanation. Its both helpful and confusing at the same time!
Old Jun 20, 2007 | 09:43 PM
rel3rd's Avatar
rel3rd
Obviously, Vader is mixed up, as there is lift at the cam lobe, and gross (or total) lift like you pointed out above, which is the actual lift after multiplying lobe lift times your rocker arm ratio.
Using the cam info the original poster linked to,
Duration @ .050"
212* Intake/218* Exhaust
Gross Valve Lift
.488" Intake/.495" Exhaust (with 1.5 ratio rocker arms)
Personally, I'd simply either include a copy of the actual cam card with the other requested chip info, or provide them with the link you provided us with above.
If you tell them your cam's lift @ .500" is .488" and .495", then he will think you are nuts , as that doesn't make a bit of sense.
Old Jun 20, 2007 | 10:55 PM
Muffin's Avatar
Muffin
This is a dual pattern cam. Kinda common. Exhaust lobes are more aggressive. Longer duration and lift, than the intake. rel3rd is correct if you wish to be very accurate.
Old Jun 20, 2007 | 11:59 PM
vader86's Avatar
vader86
Duration @ .050"
Gross Valve Lift
yeah i've got too much on my mind with this dissertation, my mistake
i mean gross lift
Old Jun 21, 2007 | 08:28 AM
Muffin's Avatar
Muffin
An afterthought: A general discussion about SBC cams will almost always assume 1.5:1 rockers when gross lift is discussed. With the increasing popularity of 1.6:1 and even 1.7:1 it might be a good idea to ID the rockers early in the conversation.
To Understanding cam specs
