When it rains...it pours
Old Jun 23, 2007 | 06:46 PM
RRT vette's Avatar
RRT vette
Default When it rains...it pours
in my car. I haven't drove the 86 in rain in years. Got out in a steady rain a few days ago and there was a continious/steady drip right above the front door speakers on both sides. The weatherstipping is not in real bad shape. The targa top was on tight and the windows all the way up. I will need to investigate further as to where the leaks orginate, but wondering if there is a product I can use rather than replacing the WS?
Old Jun 23, 2007 | 07:30 PM
vader86's Avatar
vader86
Mine leaks in the same spots. Expect some leakage next at where the B-pillar meets the targa/window.
You can try the silicone grease, but I didnt have much luck with it. That really needs to be put on them from day one, once its dried out it may be of only little help.
And if you replace any strip, better replace it all. Don't do the A without doing the strip along the targa, because you'll see then how much its shriveled up over the years. I shouldve done the targa when I did the A.
Old Jun 23, 2007 | 08:06 PM
RRT vette's Avatar
RRT vette
I agree with you vader. The WS will need to be replaced in the next few years. I will most likely replace all of it when I do....might as well. I try keeping dielectric grease on it as well. I took a quick peek after the initial post and see where the leak might be coming from the metal frame on the outside of the windshield...there is a small crease. Need to start pouring water on these areas and see what happens.
Old Jun 23, 2007 | 08:37 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
My weatherstripping is not choice by any means. I always had a rather bad leak at the RF corner of the top during heavy rain and when going through drive through car washes. I just got used to throwing something over the front speaker on that side when doing the car-wash thing to prevent it's being drenched. A while back I developed a helluva rattle in the top and traced it down to one of the latching brackets coming loose in the body. While tightening up that hardware, I ended up adjusting all of them to perfection. Now it leaks nary a drop.
Old Jun 23, 2007 | 09:54 PM
Travis93's Avatar
Travis93
Mine leaked in the same spot after a windshield replacement. Ended up that they did not reinstall the metal strips that hold the weatherstripping right and it leaked between the glass and metal strip. Best weatherstripping in the world does no good if water just runs around whats holding it in place.
Old Jun 23, 2007 | 10:04 PM
RRT vette's Avatar
RRT vette
I believe this might be the cause of my problem. I had a windshield installed 5 years ago, but only driven the car less than 1,000 miles since and the first time in rain was a few days ago.
Old Jun 23, 2007 | 10:18 PM
Demonic85's Avatar
Demonic85
Mine leaked pretty bad like that last year. Last Fall I put silicone grease on the weatherstripping and havent taken the top off since and it has not leaked. I think the heating and cooling process helped. It was covered in a 3 inch thick sheet of ice.
Old Jun 25, 2007 | 01:33 AM
ineVETTEable's Avatar
ineVETTEable
Hey CK,
are you saying the bolt holes for the targa top are adjustable in the w/s frame and the also in the halo?
Old Jun 25, 2007 | 12:05 PM
ZeroHer0's Avatar
ZeroHer0
I had similar leaking problem (amonst others). I adjusted the window forward and tighter and seems to work so far. Got rid of wind noise and 99% leaks, except portion at bottom back of glass. I just need to space WS for that.
Old Jun 25, 2007 | 04:17 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
x100000000
Old Jun 26, 2007 | 10:17 AM
rick lambert's Avatar
rick lambert
To answer ineVETTable....yes, they are adjustable. To help RRT, before you replace them try this (learned from a auto glass guy) next time the top is off, and it's a nice day apply some regular vaseline to the weather stripping,let it sit in the sun, unlike silicone the vaseline causes the weather stripping to swell...worked for me.
Old Jun 26, 2007 | 10:30 AM
ineVETTEable
I've had my top off a couple times and now when I hit bumps in the road I here it bounce or rattle. I'm gonna have to check into that adjustment...thanks!
To When it rains...it pours
