You'll have to go under there and check. It could be something benign like the air tube to the cat, a loose heat shield, or something serious like rod knock from a spun bearing.
my 89 had a rattle that sounded like it was under the car, turned out to be a the water pump pully wobbling...its worth a look see.
Other than that...the visor rattles, the door, the seat..the side mirrors, the dash, the 6 speed, the widnows, the center caps the mufflers, the on..and on...and on......
Everything on my car rattles. I want to get some sound deadening material from midamerican to help hush the door rattling when I hit bumps and help keep the window tapping from sounding so loud.
Very good chance its the heat shield around the cat
..i have an 88 and i started getting a rattle when i would raise the rpms...it too sounded like it was coming from underneath the car....
....i tracked it down to the aluminum cover that mounts with 3 torx screws that is over the distributor!...it somehow (even while tight) would resonate....
...so, i merely took a large "o" ring (maybe 1 1/2'' dia) and placed it under the aluminum "cover" and on top of the plenum, tightened the screws down again and voilà, no more "rattle".....
