Reverse Lights not working
Old Jun 28, 2007 | 11:03 PM
bobmarshall's Avatar
bobmarshall
Default Reverse Lights not working
My newly purchased 94 with manual transmission. Backup lights not working. Bulbs look ok. Where should I start looking?
Old Jun 29, 2007 | 07:22 AM
c4sforever's Avatar
c4sforever
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Take a look at the reverse switch on the tranny.
Old Jun 29, 2007 | 12:39 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
That would be the second thing I'd look at.
This first would be the fuse. (some people pull that fuse to kill the CAGS, but it also kills the backup lights)
Larry
code5coupe
__________
liberals are just children that never grew up....
Old Jun 29, 2007 | 10:45 PM
bobmarshall
Default Which fuse controls the CAGS?
Which fuse controls the CAGS? There is nothing listed on the fuse panel or the manual. There is a fuse for back up but it's ok.
Old Jun 30, 2007 | 10:42 AM
lspalding's Avatar
lspalding
Swapping out the reverse switch on the trans fixed mine.
Old Jul 1, 2007 | 12:39 AM
jfb's Avatar
jfb
You can test the reverse switch to prove if it is ok instead of replacing it automatically.
Old Jul 1, 2007 | 10:41 AM
bobmarshall
Default testing reverse switch
Do you know the procedure to test the switch?
Old Jul 1, 2007 | 11:17 PM
jfb's Avatar
jfb
Unplug the switch and jump the socket, with the ign on, your backup lights should be on. Measure the resistance of the switch while unplugged and with the shifter in reverse. It should be the same resistance as touching the ohmeter probes together, that is, essentially zero ohms.
To Reverse Lights not working
