Another headlight question.
Old Jul 2, 2007 | 08:52 AM
86SilverBullet's Avatar
86SilverBullet
Default Another headlight question.
Haven't posted much since I signed up, been working on my e86 restore. I have used the advanced search (what a sweet resource) but can't find my particular headlight problem (driver's side). All wiring has correct voltage verified. Replaced motor. Have had it apart several times and can't find the problem. Headlight will work several times and then its like it gets bound up. Unplug, manually turn headlight some, plug back in and it will work fine for say 4 or 5 times and then nothing (bound again). Repeat the process and it will work for some time. When I manually turn it, it is real hard to turn at first and then turns fine. Anyone have any ideas. It is the older style motor with the gears (not bushings). Any help is appreciated.
