Odometer question
Old Jul 3, 2007 | 09:59 AM
tooltime47's Avatar
tooltime47
Default Odometer question
I am looking at purchasing a ZR1 with low mileage but 4 previous owners. The last owner has service records since he owned it but none for the previous owners. How easy is it to turn back the mileage on a C4. The car is in very good condition but future value may be affected if I can not document the mileage. Or, is it best to stay away from cars without all documentation? Car fax may be of some help but may not tell all. What do y'all think?
Old Jul 3, 2007 | 10:09 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Generally speaking, you have to document that the mileage is NOT correct, barring evidence or appearance to the contrary. The mileage is resident in the BCM (body control module, also called the central control module) and can be changed by replacing the module. If documentation matters to you, you probably should stay away from cars without it. On earlier cars that were easily cloned, documentation is far more important.
Old Jul 3, 2007 | 10:15 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Turning back the odometer on a C4 is not like the old days where you attached an electric drill to the odometer cable and spun it backwards. It's a lot more complicated. A Carfax will show if there was a steady increase in mileage, and, if the car has been registered in the same state since new, the DMV would also pick up on a tampered odometer. As far as service records it's not unusual for early ones to be missing (although I'm surprised that any ZR1 owner would be so careless). I would not consider missing records a deal breaker. Ask the current owner if he has the name of the person he bought from. You may be able to trace the car back to its original owner.
Old Jul 3, 2007 | 02:59 PM
trulytex's Avatar
trulytex
Originally Posted by jrzvette
A Carfax will show if there was a steady increase in mileage, and, if the car has been registered in the same state since new.
Spend a few dollars and run a Car Fax on it. Don't be "Penny Wise & Dollar Foolish".
Old Jul 3, 2007 | 03:46 PM
All2kool's Avatar
All2kool
Very sound advice. The $24.95 will be money well spent. Hell, pay $29.95 for an unlimited amount of CarFAX'es.
Old Jul 3, 2007 | 05:01 PM
tooltime47's Avatar
tooltime47
I do plan to get an updated carfax. The owner gave me one dated from 2004. The mileage does show progression but the mileage was not recorded when the first owner sold it. It's been titled in four states. That is what got me wondering. $29.95 for unlimited carfaxes sounds good since I plan to look at 3 or four cars.
Thanks for the replies.
Old Jul 3, 2007 | 05:21 PM
wayne lowry's Avatar
wayne lowry
If the title and carfax are clean that is about the best you can hope for. Rolling the odometer back on a C4 would be a challenge however there are other tricks with these cars. Look at the harness comming off the v.s.s. look for splices or cuts in the wires, look for holes comming through the center console where wires could have been run through.
Old Jul 3, 2007 | 05:31 PM
jghmczo6's Avatar
jghmczo6
Good advise, just keep in mind Carfax did not start until the mid nineties therefore accidents or damages are not on record.
Example, 1991 my car was stolen from a dealer in Pasadena California, theif took the car to San Francisco and did 13k in damages, driver side front frame bent inward, it does not show on Carfax.
Hope this helps
Old Jul 3, 2007 | 08:18 PM
RRT vette's Avatar
RRT vette
The mileage is easy to change especially on the 90-96 C4's. You just have to replace the CCM (in the dash behind the radio next to the firewall). If the interior/exterior looks to be about the same as the mileage, I would say it would be safe.
Old Jul 3, 2007 | 09:29 PM
wayne lowry
You have to have a scan tool to program the mileage into the new ccm.
I am not CERTAIN but I THINK you need a TECH ONE to do this.
Old Jul 3, 2007 | 10:44 PM
RRT vette's Avatar
RRT vette
You need a TECH 1 to intergrate the donor CCM to the in car ECM/PCM before 100 miles is put on the car. IIRC
Old Jul 3, 2007 | 11:54 PM
c4cruiser's Avatar
c4cruiser
The CCM (behind the radio) holds the mileage and it can't really be changed. The CCM also has the VIN recorded in it and data for certain options lile the C68 Climate Control and the FX3 Selective Ride Control which is standard on ZR-1's. The CCM will store any error codes for these two systems.
When a new CCM is installed, you do have the 100 mile limitation before the CCM will not accept any odometer milage input. It effectively locks out any changes after that mileage is reached.
To Odometer question
