[audio] Need help
Old Oct 29, 2001 | 06:11 PM
MBVette's Avatar
MBVette
St. Jude Donor '05-'06-'07-'08-'09-'10
Default [audio] Need help
ok I am trying to finish up my install. But I cant find the damn antena wire. It was not attached to the back of the stock HU (bose gold) I was told it was behind the passanger vents. I looked back there and there are tons of wires but none look like they are attached to anything Bose. Where do I look to find this thing?
Old Oct 29, 2001 | 06:49 PM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
Default Re: [audio] Need help (MBVette)
Are you looking for the actuall antena feed or the remote-on to raise/lower the antena. The feed is on the control unit which is buried underneath the glovebock. You'll have to remove the kickpanel under the glove bock and look for a rectangular silver box. This is the actual radio on the 92 Bose Gold. I actually ended up just pulling the whole unit since I was replacing the head unit anyway. If you are looking for the remote on for the antena, I never found it. I was easier just to run a new trigger wire all the way to the back. If you pull the black trim piece that runs around the inside of the hatch, you'll find the wiring harness for the antena just in front of the gas tank flap. Hope this helps.
