Quick question, ned help about rims
Old Jul 5, 2007 | 04:40 PM
Fast Doc's Avatar
Fast Doc
Default Quick question, ned help about rims
I want to buy a rim off of ebay to replaced a right front one I damaged on a curb .
I was directed to this auction, but the rim if off a ZR-1. I have a stock 1996 LT-4.
http://cgi.ebay.com/ebaymotors/91-96...QQcmdZViewItem
Will this fit?
Sorry to be rushed but if it will fit I need to get a bid in .
Thanks.
Fast Doc.
Old Jul 5, 2007 | 04:56 PM
corvettedan22's Avatar
corvettedan22
I dont know but make sure it will sping the right way.
Old Jul 5, 2007 | 05:04 PM
Googan's Avatar
Googan
Correct me if I'm wrong, but I'm pretty sure its the right offset for your car. It says the offset is 56mm.
Edit: Here is a quote for the tech faq.
"88-96 base
8.5"/2 - 56mm/25.4 = 2.05"
9.5"/2 - 56mm/25.4 = 2.55"
(also used for fronts on some models)"
According to this, the wheel should fit your car. Hope this helps.
Old Jul 5, 2007 | 05:25 PM
Fast Doc's Avatar
Fast Doc
"88-96 base
Aren't the ZR-1 wheels wider?
Old Jul 5, 2007 | 05:41 PM
Googan's Avatar
Googan
Only the rear zr1 rims are wider, the fronts are the same as yours.
Old Jul 5, 2007 | 06:10 PM
Fast Doc's Avatar
Fast Doc
OK, I'm getting there. What width are my front rims?
Old Jul 5, 2007 | 06:12 PM
toptechx6's Avatar
toptechx6
should be 9.5
Old Jul 5, 2007 | 06:14 PM
Googan's Avatar
Googan
The fronts are 9.5" wide. What size are the tires on the front of the car now? If they are 275/40/17, then your front rims should be 9.5" wide.
Old Jul 5, 2007 | 10:43 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
The stock rims on the '96 CE's are 8.5".
Old Jul 5, 2007 | 10:46 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The stock front wheels on my 1996 LT4 were 8.5 inches wide.
255/45 17 front tire, the wheel is 8.5 inches
285/40 17 rear tire, the wheel is 9.5 inches
Old Jul 5, 2007 | 11:31 PM
Googan's Avatar
Googan
Did the collector eddition come with the a-molds or sawblades?
Old Jul 6, 2007 | 12:16 AM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
Came with A-molds, but he's got sawblades. Stock wheel size on 96 were 8.5" unless you had Z51 then they should be 9.5's. You need to check to see what size you have.
Old Jul 6, 2007 | 12:33 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
That wheel on EBAY is a standard 91-92 wheel. It was also used on the front of the 91-92 ZR-1. The wheel you need has a machined center and painted turbines, and was used from 93-96 (assuming your avitor picture is the wheel you are looking for) and most likely 17x8.5. I guess if the guy calls it a ZR-1 wheel it's worth more money
Old Jul 6, 2007 | 09:35 AM
teebee's Avatar
teebee
I didn't catch that the first time through. It is indeed a 91-92 wheel (painted center machined lip). Have you checked the size of tires on your car yet? if they are the 275's more than likely when the previous owner changed them out to sawblades, he put 9.5's on all around. Or if they are 245's you probably have 8.5's in the front. If you take the wheel off it the size should be cast in back and say what size it is. Then you can start in earnest trying to locate a replacement.
Old Jul 6, 2007 | 11:10 AM
Fast Doc's Avatar
Fast Doc
Thanks for taking the time to respond guys.
My car came (to me) with the sawblades, not the proper CE wheels.
Maybe someday I'll upgrade to some nice chrome CE wheels, or...........
Save my money and get a C6 someday when the C7's come out.
Old Jul 6, 2007 | 12:34 PM
zr1fred's Avatar
zr1fred
One of our supporting vendors sells the repro ZR-1 in the correct silver for a CE for under $600 shipped. There are also a couple of outlets on EBAY that sell the same wheel (You can also get them chrome or polished). You may want to have your wheel refinished, usually $85-$130/wheel.
To Quick question, ned help about rims
