washed engine now it won't start
Old Jul 9, 2007 | 05:15 PM
JRS 94's Avatar
JRS 94
Default washed engine now it won't start
Hey folks,
1994 C4 LT1. Washed my engine today with the engine running to avoid cracking anything, used simple green then the garden hose, car died and won't restart. Is this a lesson in optispark? or did I get something else wet? Hooked up the code scanner and there are no codes present. Anyone with this experience out there? Thanks in advance...
Old Jul 9, 2007 | 05:18 PM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
hmm maybe the opti got wet
Old Jul 9, 2007 | 05:26 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
engine + garden hose = bad.
Chances are you drowned your Opti
Old Jul 9, 2007 | 05:48 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
sounds like it:
Old Jul 9, 2007 | 05:55 PM
JRS 94's Avatar
JRS 94
thought so too, guess I wait it out now. Really don't like this behind the water pump design. Thanks for the quick reply's we'll see how long this takes.............
Old Jul 9, 2007 | 06:39 PM
ballertyped's Avatar
ballertyped
Originally Posted by JRS 94
Hey folks,
Why did you do that????
Old Jul 9, 2007 | 06:51 PM
nickyg's Avatar
nickyg
Water and opti don't mix
Old Jul 9, 2007 | 06:54 PM
JEFNLSA's Avatar
JEFNLSA
Point a hair dryer/leaf blower at it and hope for the best.
Old Jul 9, 2007 | 07:03 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Hope it dries out or this could be a very expensive lesson. Never wash LT1/LT4 engines. I wipe my LT1 engine down with a damp rag. Haven't had any problems keeping the engine clean.
Old Jul 9, 2007 | 07:19 PM
Repzard's Avatar
Repzard
Hey folks,
Washing engine with hose and Opti is a
Wish you luck
Old Jul 9, 2007 | 08:29 PM
JRS 94's Avatar
JRS 94
Car is back running, a couple heat cool cycles should do it. I won't treat it like a normal chevy again. Thanks for the ideas and the wisdom.
Old Jul 9, 2007 | 08:40 PM
JD'S WHITE 93's Avatar
JD'S WHITE 93
Great, I washed mine once and it was fine, I didn't know any better so don't feel too bad. I think antifreeze is what kills them more so than water but I still wouldn't do it again.
Old Jul 9, 2007 | 09:23 PM
vette92_1's Avatar
vette92_1
Same here, I washed mine when I didn't know any better shortly after I purchased my car about 8 - 9 years ago. I haven't had to replace the opti yet. That was also 80,000 miles ago, so now the opti has a total of 161000+ on it.
Getting it wet is not good but as long is it is water and not anti-freeze I don't think its the end all necessarily.
With all this said, I actually have a brand new MSD replacement for it I just haven't got around to installing yet.
Good luck with yours.
Old Jul 9, 2007 | 09:47 PM
OTS_UFN's Avatar
OTS_UFN
Next time "simple green" or other cleaner, squirt on rag, rub on dirty motor, repeat. I know some guys that go total freak and use q-tips, tooth brushes, and dental picks (plastic ones) .
In the car care forum some use the tire cleaner that you spray on and walk away. Used it on my dads caddy and my truck, works well. Leaves everything nice and shiny too. With the spray you can control where you put it. I was conservative and avoided the obvious pitfalls.
Old Jul 9, 2007 | 09:59 PM
91DRM's Avatar
91DRM
From: Isle of View "Mofo skated me, that was my up!"
Here's the fix $$$
Old Jul 9, 2007 | 10:31 PM
Cessnapilot89's Avatar
Cessnapilot89
What do you guys think of using engine brite on a 1989 L98?
Old Jul 9, 2007 | 10:44 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I wont ever use it again..it stinks,its slimy and didnt seem to do that great of a job on engines I used it on years back.Didnt do a great job taking the grime off dirty engines.
To washed engine now it won't start
Old Jul 10, 2007 | 05:17 AM
85 500 horse's Avatar
85 500 horse
I don't mean to bust your bubble, but don't be too surprised if your car dies in the near future. Those darn opti's sure do hate getting wet and even though your car came back to life, it doesn't mean that damage wasn't done. I don't want to get you upset or anything. I'm just saying that if your car dies, it will probably be the opti as the culprit. As mentioned, you should never wash your engine with water. Use the hand, rag, rub method.
Old Jul 10, 2007 | 06:36 AM
pcolt94's Avatar
pcolt94
Default So lets get it Fixed!
Have you done any troubleshooting? Check for spark at the plugs first. Then if no spark, check for spark at the coil. If it is there then the cap and high voltage section of the opti is affected.
I no spark at the coil output, then the low voltage pulse section of the opti could have been affected. But if the low voltage section of the opti died, I would think then it would throw at least a code 16 if there was no low resolution pulse present at all.
Check to see if you disconnected any plugs or such. As a matter of fact, disconnect the ICM and coil plugs and make sure they are perfectly dry. If you have air use it otherwise do your best with what ever you’ve got.
You might also check the 12 volts to the coil just to make sure you did not blow the fuse for primary power for the coil and ICM.
Best of luck.
Old Jul 10, 2007 | 07:51 AM
vetteblack's Avatar
vetteblack
Best of luck.
See post #11.
