Volt Reading
Old Jul 10, 2007 | 07:51 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Default Volt Reading
Can anyone tell me what should be the volt reading from the alternator on a fully charged battery on a 93?
After an hour of driving around the digital volt reading shows anywhere around 13.8 to 14.1v. I thought it would drop down after starting to around 12v.
Old Jul 10, 2007 | 07:53 PM
aminnich's Avatar
aminnich
It is right where it should be. You don't have a problem there.
Old Jul 10, 2007 | 07:57 PM
c4cruiser's Avatar
c4cruiser
Those reading are just fine and in the right range. Once the car is running, there are a lot of systems using electrical power and the alternator has to keep up with the load and keeping the battery charged.
With the engine and key off and using a voltmeter, you should see about 12.5v at the battery if it's fully charged.
Old Jul 10, 2007 | 07:59 PM
aboatguy's Avatar
aboatguy
Old Jul 10, 2007 | 08:18 PM
Hogan's Avatar
Hogan
Wow, ok. Cool. Only reason I bring it up is because the Suburban I have now stays around 12v. It will go just over 14v after start up then slowly drops done.
Thanks guys.
Old Jul 10, 2007 | 10:30 PM
Brtheez's Avatar
Brtheez
Don't mean to hijack your post, but when I run the AC it drops the volts down to about 12.1 to 12.2V. It puts a pretty good load on the system. The turn signals even slow down. The voltage picks back up when the compressor cycles off, but it just seems like it shouldn't effect the lights, signals etc. Any ideas?
Old Jul 10, 2007 | 10:43 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
I'd have to guess in both of your cases you have lower output alternators than what you may need in those trucks. Were they replaced?
My Blazer runs a little over 13.5V with the A/C on at idle.
Running a cruise speed, it's up to 14V.
14.7 with A/C off.
Old Jul 11, 2007 | 12:44 AM
jfb's Avatar
jfb
At 12.1 volts, you are running on your battery! I would first measure the voltage across the battery terminals and compare it to the dash voltmeter. Unless you have too low idle rpm, your dash voltmeter should read around 14 volts alternator cold and around 13 volts alterator hot.
Old Jul 11, 2007 | 02:27 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
with full load, sterio, AC, Amp, Lights, Fogs, i run 13.6 level, and 14.1 or 2 at starup
Old Jul 11, 2007 | 09:46 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Twelve volts and above, under a load, is fine.
Hogan, your system seems to be working great..
Larry
code5coupe
____________
not easily impressed....
Old Jul 18, 2007 | 09:40 PM
Brtheez's Avatar
Brtheez
Do you have a high output alternator? I replecd mine with a stock unit from AC Delco about 2-years ago. It runs between 13 and 14 under normal load, but as soon as I start the A/C it drops it way down and the lights dim and the signals slow etc. I run a trickle charge when I'm not driving. I think the previous owner replaced the battery in 2001 or2002, not positive. Any ideas would be great. Thanks.
Old Jul 18, 2007 | 09:44 PM
92LRC's Avatar
92LRC
Mine runs regularly in the 14 range. And in Florida I always have the ac on.
Old Jul 19, 2007 | 09:19 AM
runner140*'s Avatar
runner140*
Hi neighbor, me too.
To Volt Reading
