Nitrous Bottle Explosion...
Old Jul 14, 2007 | 08:37 AM
mtnman's Avatar
mtnman
St. Jude Donor '17-'18
Default Nitrous Bottle Explosion...
My car was at the mechanic the other day, and they parked her outside for a few hours in the heat (35 C or so). The nitrous bottle let go and flew around the interior like a crazed cannonball...
Needless to say I have some interior parts I need to track down...
Here's the damage rundown:
1) Pass seat leather torn and gouged
2) Pass sun visor torn (ordered - Ecklers)
3) Pass side glass gouged
4) Console cover gouged (ordered - Ecklers)
5) Dash slashed
6) Interior panel on pass side of console that continues from the dash to the floor slashed
Damage could have been MUCH worse, so I suppose I should be happy...
Can anyone point me to where I can get the remaining parts?
Tks!
Old Jul 14, 2007 | 08:40 AM
85 Stalker's Avatar
85 Stalker
OMG!!!
Did you have a blow-down tube on the bottle???????
At least nobody was hurt - plastic and leather can be replaced.
mtnman's Avatar
mtnman
Pictures:
Old Jul 14, 2007 | 08:41 AM
mtnman's Avatar
mtnman
Blowdown tube was in place on the bottle... Not sure if the pressure was too great and just yanked the brackets out of the floor. They were only held in the fibregalss floor with the rubber expandable bolts... Suppose I should have checked the mounting when I bought the car... Oh well - live and learn...
Old Jul 14, 2007 | 08:54 AM
85 Stalker's Avatar
85 Stalker
I just went to Summit and bought my blowdown tube ($21.00) because of your post. I've put it off far too long, and have thought about this very subject. Now I need to figure out the best way to route the blowdown off the bottle. I may also run a safety band strap to the roll cage for added insurance....
Once I get the car back from the tuner (BackStreet Performance), I'm going to add some more support to my brackets.
Old Jul 14, 2007 | 09:20 AM
etown brawler's Avatar
etown brawler
don't all nitrous bottles have a pressure relieve valve in case something like this happens ? the blow off tube only releases the nos to out side the car is this correct ?is it not basically just a tube ,or does it replace the relieve valve? i would say that bottle has a faulty relieve valve and would not reuse it.
Old Jul 14, 2007 | 09:23 AM
mtnman's Avatar
mtnman
I believe all bottles have the valve - and yes, the tube is just to direct the gasses to a safe area...
My tube was in place, and routed through the floor of the hatch area.
I believe the problem was that the bottle brackets were not mounted securely enough to the floor. So when she blew, the flow of gas through the tube was enough pressure to pull the bottle brackets out of the floor, and then the carnage began...
Old Jul 14, 2007 | 09:26 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm glad it wasn't any worse. But this is just one more reason why I don't mess with this stuff. I guess I'm old school but I like my HP real and on demand. Does anyone around here still have pics of that nice C5 that burnt to the ground due to a nitrous explosion?
Old Jul 14, 2007 | 09:29 AM
ragged claws's Avatar
ragged claws
[QUOTE=etown brawler;1561070592] the blow off tube only releases the nos to out side the car
I thought that Nitrous Oxide was laughing gas. Why in the world would anyone want to release it to the OUTSIDE of the car?
Old Jul 14, 2007 | 09:54 AM
PUNISHER VETTE's Avatar
PUNISHER VETTE
yep. live and learn. I'm doing it every day.
Old Jul 14, 2007 | 10:17 AM
mtnman's Avatar
mtnman
Can anyone tell me where to get
- replacement seat leather
- dash
- dash - to - console trim piece
- pass. side glass
Old Jul 14, 2007 | 10:36 AM
RWD_tech's Avatar
RWD_tech
exactly
Old Jul 14, 2007 | 10:43 AM
mtnman's Avatar
mtnman
Trust me, the Lingenfelter 383 has plenty of HP off the bottle as well...
Old Jul 14, 2007 | 10:52 AM
etown brawler
- dash
- pass. side glass
for the seat leather i would check out wilcox corvette parts ,window i might be able to hook you up .let me check sunday what i got .i live in edmonton not to far away from millet .
Old Jul 14, 2007 | 11:14 AM
mtnman's Avatar
mtnman
Thanks, Let me know!
Old Jul 14, 2007 | 11:33 AM
lefoy84's Avatar
lefoy84
If the pop off valve opens, the mounts have to be strong enough to hold a small rocket motor.
Old Jul 14, 2007 | 12:27 PM
redwing76's Avatar
redwing76
[QUOTE=ragged claws;1561070669]
To Nitrous Bottle Explosion...
Old Jul 14, 2007 | 02:03 PM
Corvette Kid
Because most of you are goofy enough without the giggle-gas, that's why!
Old Jul 14, 2007 | 03:15 PM
Powerdrive's Avatar
Powerdrive
Wow ... things could have been much worse.
Check this out http://www.saturnspeed.com/nitrousexplosion.htm
Old Jul 14, 2007 | 05:41 PM
etown brawler
i wonder if it just makes you laugh or knock you right out ,i always wondered but dont have da ***** to run the test .
