Gas Filter Change Complete / Install info _ Pics
OK well i did the filter on my 85 c4, 45k miles.
It was easy.
Located pass side near jacking point. let car sit for a day, then pushed it into the drive way.
1. Losened both sides of the fuel filter Completely
2. Loosen the fuel filter mount
3. Losened the fuel line support on fire wall side.
4. Spread the fuel lines, Gas will now leak down to a bucket and filter will fall in also. (very little gas leaked out)
5. Put it back in, make sure the flow is correct.
This took me 20 min start to finish taking my time.
Now for the good part.
85 c4, 45k miles, original filter.
Here is the pics, you can see all the junk inside of the filter and then when I banged it out all the junk that fell out.
I would say its a combo of dirt and filter deterioration.
Dan
It was easy.
Dan
It was easy.
Dan
It was easy.
Dan
Location: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
Dan,
Did you use ramps or jack stands?. I had mine on a lift and it looked tight and a real pita regardless. Fortunately, the filter case looked rather new so I'm saving that job for the spring.
Mike
Mike
Cool Hand Luke of W MI
wow, truely an amazing amount of chit!!
Does it idle any better since you changed the filter? Better acceleration? Also, how did you cut open the filter. Im curious to see in my old one but since it is covered in gas and if you use a saw...and a spark hit...bye bye....Has your filter been in there the whole 45,000 miles? Thanks. Just wondering what you thought the effects of just changing the filter was.
I just jacked up the pass side enought to get in there. Piece of cake.
Im not sure if it runs any better, I mean the car ran and idled fine before.
At least I know it must be running better..
I cut it open with a saw.
I wasnt concerned about a spark, because its not like its going explode. Worse case it would catch on fire.. Not to mention its aluminum so I think thats less sparking....
Man, now I really need to change mine. The problem I have, which I do not know if its just me, is that the cats are right next to the filter. It's almost impossible to get a wrench in to remove any bolts. Any suggestions? Other than drop the exhaust.
good luck.
St. Jude Donor '08-'09
I used to goto my parents house to do all my work, so my car was always hot when I arrived. I just put the garden hose on a light mist and got the exhaust damp. it cooled within a few minutes, enough so it wasn't combustion hot anymore. I figure if rain gets on it and it doesnt crack from heat, water from a hose isn't going to hurt it either. That makes your "I want to change it right now" project happen that much quicker
