headlight adjustment when closed?
Old Jul 15, 2007 | 02:21 PM
C4 Luver's Avatar
C4 Luver
4th Gear
Default headlight adjustment when closed?
I was wondering if there is a way to adjust the headlight housing. One of my lights doesn't line up flush enough to the hood when closed.( one corner sits to low) its just a cosmetic thing, but you know I want to make it right!! Thanx..
Old Jul 15, 2007 | 02:30 PM
Draven's Avatar
Draven
St. Jude Donor '14
Does the headlight move around when closed and the hood closed? If it is, that is indication of another problem. If not, it's a simple adjustment. If I remember, it's a **** that moves around.
Old Jul 15, 2007 | 02:33 PM
newbecorvetteguy's Avatar
newbecorvetteguy
Try loosening the bolts that hold that cover on and readjust. If you can't move it far enough, you'll probably have to enlarge a hole to get it to move far enough. Mines the same way. Seen about a zillion others that way too. IMO it's just another example of Chevrolet's legendary fit and finish from the factory.
To headlight adjustment when closed?
