Headlight Bushing - Please Help!!
Old Jul 16, 2007 | 01:50 PM
ballertyped's Avatar
ballertyped
Default Headlight Bushing - Please Help!!
I ordered the bushing off ebay and I opened and looked at them and left them on the counter of the kitchen and somebody threw them out! You guys said that you could get them at Home Depot can you give me the exact dimentions and how to buy them PLEASE.
Old Jul 16, 2007 | 02:24 PM
bd2626's Avatar
bd2626
http://forums.corvetteforum.com/show...ghlight=bd2626
I didn't have any luck at Home Depot or Lowe's...hopefully you can!
Enjoy the Ride!
Old Jul 16, 2007 | 05:58 PM
Mike_88Z51's Avatar
Mike_88Z51
From: Sacramento, CA Money can't buy happiness - but it's more comfortable to cry in a Corvette than a Yugo.
I originally used the plastic bushings you can buy at Home Depot. Sometimes they work great and sometimes not. My left headlight is still working fine. The right side has failed again after 3 years.
GM originally used semi-soft bushings that eventually get pulverized from the opening and closing shock loads on the bushings inside the headlight gear. The shock loads destroy the bushings rather than the gear. The plastic from HD and the delrin from Eckler's are both hard bushing replacements. I believe that they will cause the gear to end up taking more abuse than necessary, or than designed for by GM. That being the case, I've decided to use the proper part this time. Go to AutoZone or another auto parts retailer and ask for Window Regulator Gear Plugs by HELP!, Part #74410. They sell for about $7.95 a set of 3 bushings. They are semi-soft and will take the opening and closing shock to the haedlight gear instead of stressing the gear. A bit more than HD/Lowes, but less than Eckler's/MidAmerica and it is the better part for the job.
Old Jul 17, 2007 | 07:22 AM
bd2626's Avatar
bd2626
Also, replace the headlights with the plastic ones, got mine at NAPA, takes a lot of weight off the unit.
Old Jul 18, 2007 | 12:45 AM
ballertyped
Thanks for taking the time, excellent advice ($11.95 in Canada though )
thanks again
Old Jul 18, 2007 | 09:53 PM
Brtheez's Avatar
Brtheez
I have an 89, what brand are the headlights?
Old Jul 19, 2007 | 01:19 AM
ballertyped
Both done now with help bushings, took 1 hour for first one, 15 minutes for the second, works perfect!
Old Jul 19, 2007 | 08:46 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
C4s began using plastic headlight lens in 1992. Previous units were glass.
They are made by Wagner and the bar code number is 427223 56054.
Model : Plastic Halogen HP6054. They are available thru NAPA autoparts and CarQuest Auto Parts Stores.
Old Jul 19, 2007 | 01:29 PM
Bob89c4's Avatar
Bob89c4
I did mine last fall, well my right side one anyway.
They are made out of Delrin .375 rod x .400 long if my memory serves me correctly. I made up several extra just to have somes spares. Wasn't sure how long these things last.
To Headlight Bushing - Please Help!!
