Someone answer this. I have a 96 Coupe and I am about to take the rotors to the parts house to get them turned. Everytime I have done so with any vehicle they usual advise that one or more them are outside specs and need to be replaced. I have been checking online and it appears that the right front rotor is more expensive than the left - usually about $25 bucks. Just looking at them on the vehicle they look the same. Can I get away with buying two of the cheaper left side rotors?
I would not buy from a place charging more for one side, it seems a greedy way to make them more money. As far as I know your rotors are not directional so yes you could buy two of the same side.
While we're on the subject of rotors....I bought slotted rotors...is there a specific rotation for them? In other words should the slot be angled towards the front as in: \ or the angled towards the rear as in: /
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I would get them turned at Pep Boys for $8 each.
Difference between vendors rotors can be night and day. Some of them get em from Brembo, some of them get them from China. Funny part is, usually both ends of the spectrum will say "Brembo" on them.
Slots and hole orientation don't mean anything. If the internal cooling vanes are directional, they need to slant towards the back of the car, like the sawblade wheels. If the internal cooling vanes are straight, then both sides should have the same p/n.
I am a firm believer in turning rotors if they are not worn too much. Make sure the turner knows what he is dong. Rotors should have a band around them to prevent chatter while being cut. No band can result in a wavey surface. You won't feel it ,like a warped rotor, but the pad will not lay flush on the rotor face.
Here is a picture of the C5 rotor, with curved internal cooling vanes. These do have to be on their specific side unlike your stock rotors with straight vanes. The slot direction doesn't really matter.
Edit, you can buy a micrometer for the extra money you are spending. They are cheap and then you can check the rotors thickness to see if it really is out of spec. The min. thickness is put into the rotor on the back of the ones I have. Also you can check run out.
Unless you have a C6, then you should put the vanes backwards on one side.
They have to come off any way so I gonna try to get them turned. If they tell me they are out of spec I am gonna order from Napa and have them shipped. I don't drive it daily so I can wait on them.
Lasr fall I put new rotors and pads on my 90 coupe. The rotors cost 40 bucks apiece plus shipping from one of the aftermarket guys on line. The pads were also cheap. The rotors had the correct ground finish and were within .0005 on overall thickness and overall runout checked with a mike and a dial indicator. Also brake pulsing at the pedal can be caused by a bad wheel bearing as I found out later. I then put all new wheel hub and bearing assy. on the car. I have had bad results with turning down rotors in my lifetime. These are your brakes you are talking about, put on new rotors. Just my .02. Allentown Ernie.
I agree get new rotors for a few more bucks. There's no price difference between left and right.
The front stock J55 rotors have directional vanes that curve backwards for cooling. The rear internal vanes are perpendicular to the center, no curvature.
