A/C Fixed
I did a search and found lots of great Information. it was the controller under the dash with the soft nipple ends that was the culprit. I did a variation of the trim fix I pulled out the controller trimmed the soft nipples and put it back in only I had a problem keeping it plugged to the other lines so I opened up a hole in the box where the connecter went and brought the whole end with numbered lines through the box so it stuck out a few inches I then plugged it in and took a tiny wire tie and slide it between the back of the connecter on the box and the other connecter and pulled the tie snug not to much as to crush the lines. I fired up the car and hit the A/C control and WHOOSH like a tornado in all positions..
thanks again to all the guys who found out who to fix this problem.. I know it saved me a ton of money. now I'm going to miss a 2 weeks of work from being upside down side ways and some other positions.. but it was well worth it.
my hardest problem was getting the electrical plug disconnected.
THANKS THANKS.....
