convertibles
Old Jul 17, 2007 | 11:47 PM
corvette8189's Avatar
corvette8189
Default convertibles
whats wrong?
i went to put the top down and i pulled the thing to unhook the top from the car and only the driver side would unhook the passangers i guess is stuck andbody have that problem or know whats wrong?
Old Jul 17, 2007 | 11:50 PM
JrsTurn's Avatar
JrsTurn
The cable is likely stretched. You can look under there and confirm the problem. You can also just grab the latch on the stuck side and turn it to release the top.
Old Jul 18, 2007 | 02:43 PM
flynams's Avatar
flynams
I agree, cable is stretched and needs adjusting is all...
Old Jul 18, 2007 | 02:50 PM
CHISGT's Avatar
CHISGT
If it is not releasing from the rear deck it may be getting caught up because your top is getting old, they tend to shrink with age. It may be time for a new top. Just a thought.
rws.1's Avatar
rws.1
that is the most likely issue
Old Jul 18, 2007 | 02:53 PM
CHISGT's Avatar
CHISGT
If it is still stuck, release the front hooks and rock it like you are putting the top down. This will release some of the pressure on the pins and they should release. Also you may have to pull the cable release while rocking the top. good luck
Old Jul 19, 2007 | 04:56 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
I don't understand what you are asking ? I think your weather strip is glued to the top and it will not release. on the passenger side front of the top.
Old Jul 19, 2007 | 02:16 PM
Biker's Avatar
Biker
As suggested above, check the cable. You might also lubricate the latch mechanism with some WD40.
Old Jul 19, 2007 | 02:52 PM
corvette8189
i got it i just shook it around and it came out thanks
To convertibles
