Drive shaft
Old Jul 20, 2007 | 04:28 AM
Puna's Avatar
Puna
Default Drive shaft
Is it possible to remove the drive shaft off an 89 vert while the c-beam is still attached? I was lying under the car yesterdat and it looks REALLY close. I will be removing the beam anyway for a clutch change so it no big deal if that has to come off first. The part where the dread begins it when I think Central Coaster said "Putting it on was worse."
Pardon me CC if that was not your quote. you have been helpful to me on this forum.
Old Jul 20, 2007 | 08:45 AM
fredk's Avatar
fredk
Yes, I did it on my LT1
Fred
Old Jul 21, 2007 | 01:11 AM
Movnviolation's Avatar
Movnviolation
Yes on my 89 coupe also!
Old Jul 21, 2007 | 01:20 AM
jhammons01's Avatar
jhammons01
I'll answer you in 24 hours after CC and I do mine.
Old Jul 22, 2007 | 04:16 PM
jhammons01's Avatar
jhammons01
Well, the fact that we loosened the C beam and took the drive shaft out doesn't really answer the question the way you posed it.
So, I can't answer from personal experience.
There seemed to be a brace from the floor pan that may impede the removal. but Like I said, we had the C-Beam loose when we wriggled it all back in.
Old Jul 23, 2007 | 10:26 PM
NASCAR314's Avatar
NASCAR314
Putting the "C"-beam back on is a real challenge in patience and bloody knuckles fowl language really helps during re-install try using floor jacks and pry bars to move the tailshaft on the trans around to facilitate getting the "C"-beam back into position. It has some movement available, but not much.
Old Jul 29, 2007 | 03:39 AM
Puna's Avatar
Puna
Thanks guys, I try not to swear...but I know all the words, "to quote the three stooges". and some times make them up as I go!
Old Aug 4, 2007 | 06:41 AM
Puna's Avatar
Puna
To answer my ow question....NO.. the beam bolts must be removed and the beam pushed aside for driveshaft removal.... I wish some had mentioned the emergency brake cable was hooked to the beam, I farted a little till I realized this and it did take a few cuss words to get off, can't wait to re-install!!!.
Old Aug 4, 2007 | 11:16 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Seriously??? I was under the impression that the C beam did NOT have to be messed with to get the driveshaft out.....
Old Aug 8, 2007 | 08:10 PM
Puna's Avatar
Puna
Mine is a convertable and it was just shy of being able to come out, like a red cu** hair, believe me I tried!
To Drive shaft
