Where is the PLUG? OBD
Old Jul 29, 2007 | 02:41 PM
Gl!tch's Avatar
Gl!tch
Default Where is the PLUG? OBD
OK, I know I am gonna get blasted on this one but I am new to the Corvette world, and learning fast! I see the talk about the codes, yadda, yadda, and am having problems with my PKE programming remotes. I found out which terminals to cross to get the codes but can't find the evasive terminal to plug into. Can anyone tell me where it may be located on a 93 Coupe??
Old Jul 29, 2007 | 03:03 PM
VetteSlave's Avatar
VetteSlave
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It's under the dash on the drivers side................
Old Jul 29, 2007 | 03:07 PM
Red Dwarf's Avatar
Red Dwarf
It shud be as Floyd described. About half way up your right shin. It's on the bottom of the lower trim panel unless a former owner taped it some where else in the immediate area. Your just gonna have to poke around..you'll find it...,I hope!
Old Jul 29, 2007 | 10:55 PM
VetteSlave's Avatar
VetteSlave
Also, just so you'll know. The number in the black plastic on the cover to that terminal is the number of the resistor in your vats keys..............
Old Jul 29, 2007 | 11:01 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Don't rely on the cover, they can be replaced and you'll end up with the wrong code... best to search and find out how to get the resistor value and the code, its all been said and posted before.
To Where is the PLUG? OBD
