1985 Dash Cluster issue
Old Jul 31, 2007 | 01:46 AM
HIM666's Avatar
HIM666
Default 1985 Dash Cluster issue
today i got an issue with the dash light when the car is moving the dasg light are closing and reopen or all the light oepning at the same time
dod someobe ever had the same issue?
probably i have a bad wire conection issue but it's kinda difficult to find this wire because under the cluster this is loaded with all kind of wire
Old Jul 31, 2007 | 12:16 PM
mikey whipreck's Avatar
mikey whipreck
I'm wondering if maybe french is your first language?
anyway- have you read through this site: http://batee.com/corvette/index.shtml
It can be very helpful...
Old Jul 31, 2007 | 12:24 PM
jfb's Avatar
jfb
The dash cluster has two circuit boards that plug together with a single row of pins on the front board to a socket on the rear board. The end pin closest to the center of the circuit board carries the backlight lamp current and this current flowing through connection resistance due to an age relaxed spring on the rear board socket, gets so hot it unsolders the pin on the front board and the backlighting becomes intermittent or totally off. Resoldering the pin will not fix this problem. I soldered a short piece of insulated hookup wire from the pin to the socket about 6 years ago on my 87 and I haven't had a problem since.
Old Jul 31, 2007 | 05:58 PM
HIM666's Avatar
HIM666
yes french is my first language
Old Jul 31, 2007 | 07:54 PM
rad928music's Avatar
rad928music
Yep thats what it is most likely, 1986 surface mount traces
Old Oct 1, 2011 | 04:59 PM
wildbill85's Avatar
wildbill85
7th Gear
do you have a picture???
Old Oct 2, 2011 | 10:25 AM
HlhnEast's Avatar
HlhnEast
This thread is almost 5 years old and its unlikely the member that posted this is still around. Follow the advice for batee and do a search for "dash repair. If then you cant find a solution, post a new thread.
To 1985 Dash Cluster issue
