Simple wheel question
Old Aug 1, 2007 | 09:41 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Default Simple wheel question
On a 94 is there a difference in front and the back wheels. I know they are directional. I’m getting new tires on my wheels, and I am getting the correct sizes for the front and rear. And since my wheels are on backwards now. I want to make sure I get them correct. thanks for being patient with new 94 owner.
Old Aug 1, 2007 | 09:44 PM
ZBRA's Avatar
ZBRA
We need to know what suspension you have.
The base suspension has 17 x 8.5" wheels on the front and 17 x 9.5" wheels on the rear. The use 255/45/17 tires front and 285/40/17 tires rear.
The Z07 suspension has 17 x 9.5" wheels all around and uses 275/40/17 tires all around.
Old Aug 1, 2007 | 09:48 PM
Nowhere Man
I have the base suspension. when I decoded my RPO sheet I got front tires 255-45Z R17 and rear tires are 285-40Z R17. I hope that is correct
Old Aug 1, 2007 | 09:52 PM
ZBRA's Avatar
ZBRA
Yep, I added tire sizes in my first post
Old Aug 1, 2007 | 09:55 PM
Nowhere Man
thanks. are there any casting marks in the back of the wheels to make sure the backs are on the back, and the front is on the front.
Old Aug 1, 2007 | 10:06 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The actual sizes are cast into the back side of the factory wheel. You will be able to tell very easy if they are clean.
Old Aug 1, 2007 | 10:33 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
The tire shop probably won't let you into the service area when they're mounting the tires but tell the service manager that the wheels are clearly marked with their size. If you're sure which wheel goes on which corner mark the correct location on the old tires with chalk. Tell to the manager that you expect the tires to be mounted properly and the wheels in the correct location and if not he's only going to have to do the job again.
To Simple wheel question
