acrylic top
Old Aug 2, 2007 | 10:36 AM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
Default acrylic top
Would like to get some other feedback on repairing the "glass" top. I have read that a mixture of fiberglass resin, fiber glass dust, and super glue is the best way to repair the crack. Then sand & buff, anyone ever attemted to repair one of these tops? Really hate to spend money on a new one given the price when it is just the corner that is damaged. ALso anyone know a good way to "repolish" the whole top?
Old Aug 2, 2007 | 01:06 PM
tek317's Avatar
tek317
8th Gear
Default acrylic top
I have a 93 coupe and would also be interested in a way to refinish or repolish the top.
Old Aug 2, 2007 | 03:35 PM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
I've been told that you can 1500 grit wet sand it, and then use mirror glaze on high speed buffer, but I (like you) am trying to get others opinions on this before I try....
Old Aug 3, 2007 | 12:24 AM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
Default Mannnnnnnn
Now I know every one out there has a crazed acrylic top.....No feedback on the post below?
Old Aug 3, 2007 | 09:32 AM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
I'd start checking vendors (Melrose Tops is one people here on the forum recommend) for a replacement top. Most places will give you a core charge on your old top. When it comes to the acrylic top, replace it, don't "repair" it.
Old Aug 3, 2007 | 09:34 AM
milsurpman's Avatar
milsurpman
ALso anyone know a good way to "repolish" the whole top?[/QUOTE]
What we use on aircraft windshields will work well on this application for removing the haze. Its called a Micromesh kit.
Here what It looks like.
http://www.aircraftspruce.com/catalo.../Micromesh.php
Old Aug 3, 2007 | 10:48 AM
STREETKNIGHT's Avatar
STREETKNIGHT
St. Jude Donor '03-'04-'05-'06-'07
Why? For a minor repair, it's better that 3-700.00 for a new one
Besides, the new one is going to break or haze in the long run again.
Old Aug 3, 2007 | 11:05 PM
H P Bushrod
Moderator Emeritus
That's why I'm glad I have the solid roof panel in my '93. The acrylic roof on my '85 got on my nerves.
Old Aug 3, 2007 | 11:30 PM
Calderone's Avatar
Calderone
You can't replace an acrylic one for a solid one ?
thanx
Old Aug 4, 2007 | 12:33 AM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
thanx
Oh I have a solid one, just would like the option to have a glass top without the $$....A buddy of mine gave it to me because it was damaged on one corner and I posted to see if any one new of how to fix the crack, it is only about 2" on one of the corners.
Old Aug 4, 2007 | 06:51 AM
STREETKNIGHT
If it were me, I'd try the repair
I had the acrylic one (3 of them) and they all broke
I've now switched to a hart top. I miss the ability to see out at night
Do the repair and have both If it was free, you really have nothing to loose
Old Aug 4, 2007 | 01:03 PM
Brian86's Avatar
Brian86
I took my top to Mexico and had it painted black for $20. It cuts down on the interior heat and protects against skin cancer now.
To acrylic top
