installing,recovering
Old Nov 3, 2001 | 07:38 PM
grumpyvette's Avatar
grumpyvette
Default installing,recovering
I just ordered a complete new interior for my 1985 vette,leather seat covers,door panels,new dash,rugs,console,etc, now I know how to build engines but interiors are new to me so can I install,recover,etc. the interior or is the work more than the average mechanic can handle ,should I get someone at an upholstery shop to do the work???
Old Nov 3, 2001 | 08:00 PM
Andy1983's Avatar
Andy1983
Default Re: installing,recovering (grumpyvette)
[QUOTE]leather seat covers
Easy (Make sure to get new foam also... it really does help)
door panels
Easy
new dash
No clue, have never replaced a dash
rugs
Carpet? Easy
console
No clue, have never installed a console [QUOTE]
Sorry I didn't have all the answers, but I have redone a COMPLETE interior including headliner, rear carpet, door panels, sun visors, seat foam, seat cover (front and back seats), isulation, carpet, and all handles on a 73 Gran Torino before. And I am a MORON when it comes to installing stuff, and this was easy as sin. :D
I have never messed with a dash or any of the components, so I can't offer input in this department.
Hope this helps,
Andy
Old Nov 3, 2001 | 08:31 PM
grumpyvette
Default Re: installing,recovering (Andy1983)
i HAVE REPLACED LOTS OF DASHS AND CONSOLES ITS THE LEATHER SEAT COVERS ON THE FOAM THAT I HAVE NEVER DONE, AND WHAT DO YOU USE TO STICK CARPET? WEATHER STRIP GLUE?CONTACT CEMENT? EPOXY?
Old Nov 4, 2001 | 09:52 PM
gh86E's Avatar
gh86E
See my tips at: http://www.corvetteforum.net/c4/gh86e/indexrp1.shtml
http://www.corvetteforum.net/c4/gh86e/indexrp2.shtml
The second one tells what adhesive to use for the carpets on the console side panels & dash kick panels.
I've had most of my dash apart. Tomorrow, if I have a little time, I'll finally update my web site (below) with pictures of putting it all together. I just finished the driver's side today. Will finish off the rear, and the passenger side next weekend.
Hardest parts?
- Getting new clutch and brake pedal pads on
- Getting old T50 torx bolts out of sealt belt mounts. The set belt receptacle bolts that go into the center console especially were extensively rusted, and it's hard to get a T50 driver into it (take hammer and pount the socket into the bolt - that give better grip and helps loosen the rust).
- Getting plastic kick panels back on properly (do before seats go back in - lie down in seat area w/feet in rear hatch area, head under dash. Then it's fairly easy to line everything up and get the screws in.
- Getting 2 broken off screws out of holes (some previous owner or service person snapped them off - still can't get either one out).
- Getting steering column back together, esp. after you take those 3 screws out way down in the column that look like the only way to feed the wire from a new turn signal stalk down the column, but a voice in your head says "you're going to regret taking thsoe screws out". Why did I do that? As I was getting all new carpets and dash pieces in, the ignition switch and turn signal stalk all of a sudden looked crappy. The side-mirror select switch will look crappy. The driving lights switch will look crappy. The door handles will lo... Heck, I think you've got the idea.
In the next day or so, I'll update my web site (below) with updated pictures.
Old Nov 4, 2001 | 10:22 PM
grumpyvette
Default Re: installing,recovering (gh86E)
thank you that was very very helpfull
To installing,recovering
