Pre-purchase Testing
Old Aug 5, 2007 | 01:08 PM
smack123's Avatar
smack123
Default Pre-purchase Testing
Hey guys - 2 quick questions. I've got a guy that wants to buy my 91 Coupe, but her would like to have it checked out before he buys it, which I am fine with, as I don't anticipate there are any problems.
The 2 elements he wants to have checked out are a compression test, and a tranny check.
#1 - What is a good result on a compression test. Is there a link / info. that will show me great vs. good vs. fair vs. poor, so that I can see what the actual compression numbers mean?
#2 - He indicated that they could do some sort of pressure test on the tranny? Anyone familiar with this? What do they test the tranny for?
Thanks for the help guys.
Old Aug 5, 2007 | 01:23 PM
vettowner1994's Avatar
vettowner1994
Compression test just shows the rings, valves and cylinder's are still in good working order, therefore holding proper compression. "Not worn out". Transmission pressure check just confirms the transmission pump and internal flow is ok. Low pressure there might mean just a dirty filter up to a transmission is worn and will need replaced soon. If a low transmission pressure is present then more diagnostics have to be done for like I said it might just need a filter change and new filter.
Old Aug 5, 2007 | 04:10 PM
smack123's Avatar
smack123
Thanks vetteowner1994 - I thought I recalled having a compression test done years ago on vehicle, and that it produced quantifiable results. (ie Cylinder #4, 124, Cylinder #5, 118, etc...
And thnaks for the heads up on the tranny check
Old Aug 5, 2007 | 04:12 PM
94z07fx3's Avatar
94z07fx3
Originally Posted by smack123
What is a good result on a compression test?
General specs are that the lowest cylinder not be less than 70% of the highest and no cylinder less than 100 psi.
There are engine analyzers that do a great job of figuring out the compression in the cylinders by measuring variations in current flow and RPM durring cranking. Those tests won't require that each sparkplug be removed. (And we all know the fun involved there.)
If you have one, a current emmisions test results sheet should be enough to show him that the engine is sound.
Old Aug 5, 2007 | 06:05 PM
smack123's Avatar
smack123
Thanks - appreciate the feedback
To Pre-purchase Testing
