Pke System Question>>>>>
Old Aug 6, 2007 | 09:14 PM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
Default Pke System Question>>>>>
On my 94, the rpo label does not show to have this option, but when I start the car, the light for this option comes on like it is an option. Where is the PKE module located on the car if I had the option? Can't find a clear enough description in the SVC MANS.....
Old Aug 6, 2007 | 09:25 PM
polo93LT1's Avatar
polo93LT1
Cinneman,
Hey - not a real huge authority - but I'm willing to bet your '94 has the PKE option.
Did you do a "search" on "PKE" in the forum? Go up to the "search" drop down box and key in PKE. It will pull a TON of info on the PKE. If you still can't find the module - come on back and I'm sure someone on here will help. PKE's were first introduced on the 93's - mine still works fine - but I suspect I'm in the minority.
Later . . . and good luck!
Old Aug 6, 2007 | 09:30 PM
CINNEMAN's Avatar
CINNEMAN
St Jude Donor '14
THX.....SCV's....
Old Aug 6, 2007 | 09:35 PM
ruby9246's Avatar
ruby9246
St. Jude Donor '03-'05-'06-'07-'08
PKE was Standard from 93-96
Some good PKE Info
http://forums.corvetteforum.com/show...m_id=34&arch=1
Old Aug 7, 2007 | 12:36 PM
95wht6spd's Avatar
95wht6spd
I don't understand the 2nd tech tip about cleaning the ball?
I open mine up and I don't see 2 gold tabs on the back, or gold in the middle. I hear the ball but don't see a way to access it, it is all a solid state circuit board?!
To Pke System Question>>>>>
