i'm going to install a telescoping hood support on my 85 as i don't have one at all. is all i need just the support? or will i need something else for the instillation? i do however have the mount for the original hood support.
You will need the top and bottom brackets for the support. Also insure the hood has two bolt holes by the upper right corner of the driver side upper fender well
If all you have is the telescoping support, you'll need te upper and lower mounts and related hardware - you 85 came stock with the scissor style hinge on the pass side of the hood only
i put an add up. no one responds. i'll try again though
It takes time, give it a few days.
Make sure its in "C4 Parts For Sale/Wanted" and that you have a nice big title of "WTB: Hood Support Brackets" or something obvious like that in there.
Sometimes it takes a few days to a week. I was looking for a new targa top once and it took about 2 weeks before I got any responses. If it bumps off the end of page 1, you can reply to your own post with a TTT (To The Top) to get it stuck back on the 1st page again.
